I've never seen dropped frames in 2 years of using a Toshiba.Originally Posted by aim15011Originally Posted by samijubalA recorder fail before 200 discs? A Funai maybe. I did have a used Ebay Toshiba fail in about 9 months, but that was used daily with RWs, sometimes a few hours a day. I've been using the second used Ebay Toshiba for well over a year now and it still works fine. Unless you just get a lemon recorder, it should last well over 200 discs. Just record one disc at a time and let the recorder cool down for awhile before doing another one and you shouldn't have any problems. My sister has a Toshiba she's been using for well over a year now without any problems.Originally Posted by orsettoaim15011 wrote:
If he goes for the separate (non-combo) recorder, have him try the $50 Funai sold at Wal*Mart. The problem is, most of the cheaper recorders in stores now are failure-prone junk, including the Toshiba DR-400 and other big names. If your friend is going to buy new, at least Wal*Mart has an extended return policy. Transferring 200 tapes is kind of intensive and he will likely have a recorder fail before he gets thru half of those tapes. I have had very bad luck with current "budget" recorders, so I'd suggest Wal*Mart as the safest retailer given their return policy. Send him there. If they have a Toshiba, great, otherwise have him pick up the Funai.he is intrested in a Toshiba DR400. Good recorder? I told him about the combos and now he rather get a standalone recorder. Whatever will work best for his fight collection.
and just curious, have you witness any "dropped frames" using both DVD Recorders? Thats something he defiantly wants to avoid. His last VHS-to-DVD conversion box (Pyro ADS) wasnt too good and dropped so many frames, he returned it the next day.
				Results 31 to 34 of 34
	Is the Toshiba great for recording tv shows as well?
 He also owns a Sony SLV798HF VCR player.
	A power drill and about 20 minutes takes care of this issue. I've done it a few times now.Originally Posted by oldandinthe way
 NOTE: Remember to remove the lid and leave the machine guts far away from a drill. You don't want metal shavings in your fans, on your boards, and in your drives.
 Adding a small fan is as easy as a power splitter and a fan, or some basic wire splicing. Do it unplugged, of course. Add a separate on/off switch, or find a power source that cuts with the machine.Want my help? Ask here! (not via PM!)
	I record from satellites. It's the best recorder I've seen for my sources. If I look hard I can see a very slight softening of the picture, other than that the recording is virtually identical to the source.Originally Posted by aim15011
  Help Converting JVC VHS to Toshiba DVD RecorderBy pwquilts in forum Video ConversionReplies: 3Last Post: 10th Jul 2010, 09:47
  JVC D-VHS HD Recorder QuestionBy nlec in forum DVB / IPTVReplies: 0Last Post: 17th Oct 2008, 20:03
  A good recorder that will transfer difficult VHS tapes?By siberwolf in forum DVD & Blu-ray RecordersReplies: 20Last Post: 12th May 2008, 09:15
  JVC HR-J7020UM Hi-Fi 6 Head VCR VHS -too good to be true?By barkingcat in forum Capturing and VCRReplies: 4Last Post: 4th Feb 2008, 13:11
  I need a GOOD VHS To DVD Recorder!By Kimiakane in forum DVD & Blu-ray RecordersReplies: 11Last Post: 13th Dec 2007, 18:24
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
