I currently own a LG LRA-850 DVD-Recorder, and a Motorola DVR. I have no clue how to connect the two. I know someone on youtube who was using a PVR and a DVD-R to get video's from his TV into the computer.
When I tried to record a program this afternoon, it didn't work and all it picked up was fuzz. Somehow the DVD-R needs to be programmed into the PVR, but I don't know how. Also, when the DVD-R was operating using our DVD player cables, it would only record channels 1-125, and I would like to record channels above that. Help would be MUCH appreciated!![]()
It won't correspond to a regular channel. You will need to select the input you are using. Most players mark them as Line IN. There are sometimes a separate button (front panel or on the remote) to choose the line inputs. Other times they are often selected using the channel selector (ie: L1, L2, 2, 3, 4, etc.).
Google is your Friend -
Your DVD-R has an analog tumer. It will not record the higher digital channels from cable.
Your DVD-R has inputs on the front and the back. You need to select the proper source to record from.
Consider reading the manual. If you lost the manual it is available in PDF format on the LG website.
PVR files on a PVR formatted disk
By keithy in forum Newbie / General discussionsReplies: 2Last Post: 22nd Apr 2009, 08:26 -
connecting a PVR and DVD/VHS unit to a TV
By affa44 in forum Newbie / General discussionsReplies: 3Last Post: 24th Dec 2008, 01:45 -
Need help connecting Hauppauge 150 PVR from TV/VCR set up
By magicfingers in forum Capturing and VCRReplies: 17Last Post: 5th Sep 2008, 06:41 -
Connecting DVD player to a PC
By ppao in forum Newbie / General discussionsReplies: 1Last Post: 22nd Mar 2008, 20:09 -
connecting laptop to PC and using both DVD drives
By debrag in forum Media Center PC / MediaCentersReplies: 3Last Post: 4th Oct 2007, 11:20
