I can't get the captures to be a VCD 2.0 compliant... Nero won't accept! Is there a way in MMC to tweak that? I have done the size to 352x288 with 25fps and se tthe bit rate to 1150000. Is that bps??? is that really the same as 1150 kbps??? I'm not sure.... I mean.. is'nt 1 kb the same as 1024 bytes?? then...
should'nt 1150 kbps be set too... 1177600 bps instead???
And about the Audio... does that encode the right way? sure it's 44,1 khz but there's no value abotu the 224 kbps sound that you need for a VCD...
Results 1 to 1 of 1
Thanx/
Lars
Anybody know how to get ATI MMC version 9.02???
By pukhog3 in forum Capturing and VCRReplies: 10Last Post: 10th Sep 2009, 17:12 -
How to use ATi MMC Multimedia Center TV
By c627627 in forum User guidesReplies: 2Last Post: 8th Apr 2009, 03:14 -
ATI AIW X800GT - ANY capture software besides MMC?
By nbarzgar in forum Capturing and VCRReplies: 23Last Post: 18th Nov 2007, 01:24 -
Anyone using MMC with X800XL VIVO-only (no TV tuner or AIW) for capture?
By palouse in forum Capturing and VCRReplies: 4Last Post: 15th Aug 2007, 02:28 -
where to download old ATI MMC?
By mencius in forum Capturing and VCRReplies: 2Last Post: 22nd May 2007, 23:44
