Howdy,
I want to rip some of my DVDs into Divx so I can put a bunch of them on one DVD.
I have a copy DIvx's Converter program I got when they were giving away licenses for free. I've also used AutoGK in the past (the far distant past)...
I'm just wondering if there's any major advantage to using either of these programs or some other program out there.
All I want is the best video possible while still maintaining good audio (5.1 if it will keep that). And I want to get the size to 1gig or less.
Divx Converter is just drag and drop the file and come back later while I know others let you change settings and such.
Are there any comparisons to the output quality of the various programs?
Thanks.
	If both programs are using the same Divx codec, then the output will be exactly the same if the encoder settings are the same. And, yes, you can use AC3 5.1 audio with Divx, if those program will let you.
 AutoGK will give you more adjustments, which, if used properly, should give you better quality. Divx converter is simple because it has a lot less options.
  Can't get DivX to work with AutoGK no matter what I do.By teapot in forum Video ConversionReplies: 4Last Post: 17th Jun 2010, 23:38
  DivX 7 pro in AutoGK Newest version?By helionfilm in forum Video ConversionReplies: 12Last Post: 26th Feb 2010, 05:46
  AutoGK + Divx Pro 6.8.5By eskro in forum DVD RippingReplies: 14Last Post: 28th Jan 2010, 03:25
  Any way to set default DivX bitrate in AutoGK ?By spidey in forum Video ConversionReplies: 2Last Post: 17th Jul 2008, 02:11
  Vob to Xvid in autoGK or Divx Converter problemBy arcangel14563 in forum DVD RippingReplies: 1Last Post: 19th Nov 2007, 18:11
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
