I have tried to do the alt f10 which should let me restore back to factory settings from the
partition off the HD..but at 28% it says can't restore error 0xd000000d
Is there some other way to restore the operating system?..I don't have any back up disks..
You arent the same person over here > http://www.chevelles.com > post 206770
From that post , it reports vista .
This wont be much fun , but lookup the hard drive manufacturer and check where they are upto on system utilities supporting vista installed systems ... cross your fingers .
As you are able to access the menu from F10 , I would atleast try using diskcheck for error's and then try again the restore ...
I havent accessed the utilities abilities to confirm the data stored in the master backup as yet ... waiting to get my hands back onto that system next few weeks ... no , mine aint broke , I have allowed another person to use it till there's is repaired .
If however , this error is directly being contributed from the inability to read files at a certain point from the master , hidden backup partition ... its pretty well a given it needs servicing ... for without the backup disc's (something you were supposed to make when you first got it) ... its not going anywhere fast .
Beyond this point it involves contacting the manufacturer or a local system tech to remedy the issue ... for without a master backup set , your out of luck
You may have been entitled to a discount purchase of master restore disc's when it was purchased ... Some salesfolk are lazy .
My rule ... if you sell it , you should know the product , inside out . -
What if I would reload the system with xp ..then try a restore from that point?
The proper restore disks with all of the Acer proprietary utilities are essential to success.
If you can bring the unit up in "safe mode" scandisk or chkdisk might help you get going.
If you have not created a set of restore disks, you should contact Acer support and BUY a set.
If you load XP or any other non-Acer supplied O/S you will need to track down the power management and other Acer proprietary utlities for that O/S. Otherwise your system will overheat and fail. This has been biting the Linux folks when they get a great buy on an Acer and try to load their system.
Since you haven't told us why you want to restore the O/S we can't comment on your initial failure, but a call to Acer support identifying your problem may be in order. -
This is a friends laptop..they had a problem with it .tried to do the restore..didn't work..they didn't make the restore disks..
is there anything else I can do short of ordering some from Acer?
If the restore failed, the original problem probably remains. If your friend didn't make restore disks, he probably also did not properly diagnose the original failure. Either go back to the original problem and attempt to remedy it, or order restore disks.
There is no magic.
acer laptop not playing avi format
By raviasr in forum Newbie / General discussionsReplies: 1Last Post: 29th Jun 2011, 02:00 -
New Acer laptop 1 USB port not working
By stantheman1976 in forum ComputerReplies: 19Last Post: 14th Mar 2011, 12:47 -
Acer Aspire Wlan
By didikai in forum Video ConversionReplies: 2Last Post: 19th Nov 2010, 18:44 -
Acer Aspire ???
By HotDamn! in forum ComputerReplies: 11Last Post: 19th Apr 2010, 12:07 -
Real Player video gives blackscreen on TV Out for Acer laptop
By NG in forum Media Center PC / MediaCentersReplies: 5Last Post: 11th Dec 2007, 13:31
