So i picked up the new LG LDA-831 DVD player over Boxing Day (the one with a USB port). It looks great and the USB port works great with regular USB flash drives, but not so much luck with my external drive. I have a Western Digital 120Gb Passport 2.5" Drive which it doesn't recognize. The drive is FAT32 as recommended, so I'm not sure if i just have to re-format and start over.
The manual says that the unit only works with specific external drives......so the question is has anyone had any luck with any external drives or know of any specific ones that work???
Try a different tool to perform the formatting: http://www.compuapps.com/Download/swissknife/swissknife.htm
Also ensure there isn't a limit on the HDD size. Some units do have size limits. If the manual doesn't specifically state a size limit, try formatting the drive after creating multiple partitions (such as 4 30GB partitions).Google is your Friend -
i might just try that program. i was hoping for a simpler option......i might just reformat (but didnt want to lose my data on it - nowhere to put it)....oh well
I have the same LDA-831 for 3 weeks,
Works great with 80G Western Digital drive (1 partition FAT32) and with any USB memory flash drives from 512M to 4G.
Try plugging it in if the harddrive has an external power supply option. I've read here that some dvd players don't have enough power to run usb drives on their own.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
What's the maximum gig HD you can use for this player and can anyone recommend a specific HD? Preferably one that keeps cool. Thanks!
External Harddrive Enclosure
By AuroEdge in forum ComputerReplies: 0Last Post: 3rd Jan 2010, 13:20 -
Suggestion on external harddrive
By jyeh74 in forum ComputerReplies: 17Last Post: 13th May 2009, 03:40 -
Use Internal Harddrive as External for ps3
By f-zer0 in forum ComputerReplies: 10Last Post: 10th Aug 2008, 18:33 -
Compatability of DVD+R DL media with LG LDA-831??
By jamiemark in forum DVD & Blu-ray PlayersReplies: 5Last Post: 21st Mar 2008, 11:07 -
LG LDA-831 All Region?
By Cort in forum DVD & Blu-ray PlayersReplies: 5Last Post: 2nd Dec 2007, 02:36
