I have a file called avseq012.dat, the size is 600 MB, but it always stops after playing 400 MB. Could anyone tell me how to fix the dat file please? Thanks in advance.
Hi turtledove3 ,
The only thig I can suggest as a starting place would be to convert your .dat file back to an .mpeg file using perhaps VCDGear and then play around a bit with it maybe demultiplexing or using some repair type software from the tools section.
Good luck.
Barry Webber.
<font size=-1>[ This Message was edited by: bazwaldo on 2001-07-28 14:56:59 ]</font>
What is the DAT file?
By coody in forum Video ConversionReplies: 3Last Post: 22nd Mar 2010, 20:29 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
.Dat File?
By niteghost in forum Video ConversionReplies: 3Last Post: 24th May 2009, 21:38 -
Video dat file played only like audio file
By newbievideohelp in forum Software PlayingReplies: 9Last Post: 14th Oct 2008, 19:31 -
How to extract a .wmv file from inside a .dat file
By Toastie in forum Video ConversionReplies: 2Last Post: 17th Jun 2007, 22:06
