Is anybody having any trouble with any dvd fab programs? Everytime I use it I get an error message that says reading/writing error control retry abort ignore or ignore all. How can I stop recieving this error message so that I am able to copy without any problems? Can anybody help?
Results 1 to 9 of 9
Hello there and welcome
Have you checked the DVD for scratches or smudges? -
This happens with *all* DVDs you have tried?
If so and if there isn't any physical damage or dirt on the DVDs ,
you could try the latest beta DVDFabHDDecrypter (is free) that just came out today and if that doesn't help try ripping from another drive or see if there is a firmware upgrade for your drive. -
In "Common settings" DVD read> check "Ignore all reading errors automatically"....see if that helps,good luck!
" Who needs Google, my wife knows everything" -
Using the fab software when trying to copy rush hour 3 it crashes everytime, what can be used to copy or to stop the program from crashing?
@ mikes01,
Are you getting any errors? Also try by disabling Path Player...
What flick you having probs with?" Who needs Google, my wife knows everything" -
You can backup Rush Hour 3 with dvd shrink with Dvdidepro working in background. I am having trouble backing up Shoot Em Up. I get the reading/writing error control message.
Did you try today's beta release of DVDFabHDDecrypter like I suggested earlier?Originally Posted by mikes01
According to release notes for DVDFabHDDecrypter, support for the protection found in that DVD was added back in December:
but as there have been some updates to the program since then, it's probably a good idea to try the very latest.4.0.3.0 (Dec 26, 2007)
- Merry Christmas!
- New: Added support for a new copy protection as found on "Rush Hour 3"
DVD Fab HD
By GAR in forum Newbie / General discussionsReplies: 9Last Post: 10th Sep 2010, 19:38 -
Dvd Fab hd
By durkinjt in forum Blu-ray RippingReplies: 2Last Post: 29th Nov 2009, 18:43 -
DVD FAB HD
By herdbull in forum DVD RippingReplies: 1Last Post: 11th Mar 2009, 10:47 -
dvd fab
By kattiemylady in forum DVD RippingReplies: 6Last Post: 28th Dec 2008, 10:47 -
DVD Fab Platinum Frequently Fails, But DVD Fab HD Works. Why ?
By MacPCConsultants in forum DVD RippingReplies: 7Last Post: 4th Mar 2008, 04:39
