Hello all,
I've been trying to use Gordian Knot Rippack 0.35.0 to convert my avi files to Xvid 1.1.3, but for some reason, Gordian Knot simply won't read the avi's with the codecs that I use and I was hoping that someone could give me some advice on which lossless codecs as a source video work well with Gordian Knot.
I have several videos encoded with the CineForm codec, which is a very good codec, however Gordian Knot won't read the file correctly if at all. For instance, a 30 minute video is read as only about 00:03:41 (hh:mms) and doesn't display any video.
I tried converting part of the video to HuffYUV 2.2.0 and Lagarith 1.3.14, but Gordian Knot still won't read the videos at all.
I want to use Gordian Knot to convert to Xvid because it can encode the video in 2 pass mode.
Also, here are some more specs on the video:
FPS: 23.976
Resolution: 1280x720
Aspect Ratio: 1.778 (16:9)
Any advice/help on this is greatly appreciated,
Thanx for now,
Cheers,
ziggy1971 8)
P.S. Although Gordian Knot won't read the files, VirtualDubMod 1.5.10 reads them just fine and Gordian Knot uses VirtualDubMod. I'm confused!!!![]()
Avidemux & Conversion Issues with Sony MTS Format
By callmebc in forum Video ConversionReplies: 24Last Post: 11th Mar 2012, 12:42 -
Issues with Proper Format for DVD
By hughgogirl in forum Video ConversionReplies: 4Last Post: 29th Dec 2009, 19:20 -
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 12:12 -
format issues
By maddi.noir in forum Newbie / General discussionsReplies: 4Last Post: 9th Nov 2009, 03:59 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
