Is there an equivalent to „Gspot“ for ASF files? Looking for facility to show compression, codec and other info, please. Any help here much appreciated
Thanks, neat facility MediaInfo but my problem is following.... with an ASF file (from camcorder) Gspot shows „Codec M4S2“...“Compliant MPEG-4 v2 Simple Profile“....but Status column says „Codec Status Undetermined“. I have “FFDshow” filter appliance installed (WinXP). The file plays o.k., but should I nevertheless install M4S2? I thought it should install with Media Player v. 9 and I cant find it on MS site.
As far as I know, GSpot has that quirk with ASF/WMV files, regardless of whether or not the codecs/filters/etc. are installed on the system - it shows "Codec Status Undetermined" for both the video stream and audio stream. I'm not sure it entirely supports ASF/WMV. You're not experiencing any problems playing or using the videos otherwise, are you?
Editing ASF Files. What software
By PanesarV in forum EditingReplies: 12Last Post: 29th Jul 2012, 18:30 -
Notepad to spellcheck SRTs with underscore facility
By cal_tony in forum SubtitleReplies: 8Last Post: 2nd Nov 2011, 22:43 -
Please tell me what's wrong with my video file! + How do I examine vide0??
By OM2 in forum Newbie / General discussionsReplies: 6Last Post: 27th Dec 2008, 22:50 -
Conversion from asf files to avi or mpeg
By Jescal in forum Video ConversionReplies: 1Last Post: 23rd Jan 2008, 16:37 -
Pixellating ASF Files
By camboyedit in forum Video ConversionReplies: 5Last Post: 19th Nov 2007, 08:07
