helloi have an issue with some of my vhs tapes that i am trying to convert with a standalone dvd recorder (in my case, a panasonic). for some of them, the playback is fine when not passing through the dvd recorder. when it passes through the dvd recorder, i get occasional vertical jitter. my guess is it happens only in certain cases where i have tapes recorded once in ep mode and then recorded again in ep mode. what would fix this? i tried these tapes with a different dvd recorder and got the same exact jitter.
thanks!
a TBC would probably help
this is one reason recording in ep isn't recommended
you're bound to finally get something good...and then you're screwed -
Try a video stabilizer...as another option
AG-1980: Vertical jitter with or without AVT-8710 TBC. Ideas?
By Mini-Me in forum Capturing and VCRReplies: 7Last Post: 4th Aug 2011, 10:31 -
Jitter during transition in and out...
By Huntr777 in forum MacReplies: 18Last Post: 15th Jul 2011, 14:51 -
vertical jitter reduction filters?
By lordsmurf in forum RestorationReplies: 14Last Post: 26th Nov 2009, 03:19 -
What if TBC doesn't fix the vertical jitter?
By moxiecat in forum RestorationReplies: 8Last Post: 1st May 2009, 07:31 -
Why Does One Mpg Jitter and One Doesn't? And Why The Jitter?
By abrogard in forum Video ConversionReplies: 10Last Post: 17th Nov 2007, 03:21
