I'm looking to spend $600-800 on an editing system. Any suggestions?
Results 1 to 12 of 12
breaking news is my life...
The entire system or just a computer or just software or a computer upgrade with software?
$600-$800 will get you a nice editing software suite, or a decent effects board.
Avid http://www.videoguys.com/liquidfamily.html
Canopus (Grass Valley) http://www.videoguys.com/ediuspro4.html
Vegas+DVD http://www.videoguys.com/vegasvideo.html
What is it your looking to accomplish? -
i have software...just looking for a good brand of computer. Dell or HP or something else. Looking to do some hardcore editing. thanks for the quick reply!
breaking news is my life... -
What software do you have? What editing style are you looking for [how many layers/effects will you be using, like will you be doing quick news cutting or fancy commercialistic effect sequences]?
I'm currently using Premiere Pro, upgrading to Premiere Pro 2.0
I edit a lot for freelance work. So I will be cutting anything and everything.
Looking at a computer, w/o monitors, with 160-300 gig internal hard drive, either AMD or Intel Processor, more than likely a dual core, USB 2.0, and 1 gig of RAMbreaking news is my life... -
Well, working video, you're going to want at least two drives, one for your system and software and another for your video. You're also going to want XP Pro and at least 2GB of RAM. I do well on a notebook with a T2500 (centrino Duo 2.0 GHz per) 2 GB of RAM that cost roughly $2000 about a year and a half ago... something similar could be nice for you. I recommend ATI graphics cards for video and 3D work, as they render highly complex scenes faster without quirks.
hey,
while browsing the net i found this emachines PC
http://www.emachines.com/products/products.html?prod=T5246
for $430...any good?breaking news is my life... -
Core2Duo or Quad. 2GB RAM to start.
Premiere Pro requires SSE3 support.
What video format? This determines your disk drive system.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I'm not sure I understand what SSE3 is. Video format...i think just DV, no HD.Originally Posted by edDVbreaking news is my life...
http://en.wikipedia.org/wiki/SSE3Originally Posted by newsphotog
Some AMD CPUs support SSE3 others don't. DV format editing is fine on a second hard drive. In a pinch (e.g. laptop) you can get by with one drive.Recommends: Kiva.org - Loans that change lives.
I edit in Premiere Pro CS3 and I don't have SSE3. I edit DV, uncompressed, MPEG, HuffYUV and MJPEG. I've only got 1GB RAM, so it's a bit slow. It runs better on 2GB or more.
All that said, if buying a new computer, there's no reason to avoid a Core 2 Duo system.
A used RT card may be helpful, as somebody else mentioned.
News photog, huh? What do you primarily shoot? (Both equipment type and topics covered).Want my help? Ask here! (not via PM!)
Installing software suites on external hdd's, pros/cons ? ... [SUCCESS]
By vhelp in forum ComputerReplies: 8Last Post: 6th Dec 2009, 22:25 -
how to edit video that will look good on tv
By James 1967 in forum Newbie / General discussionsReplies: 1Last Post: 9th Jul 2009, 21:32 -
Good software to tag image and video streams that doesnt edit the headers?
By gfxcat in forum ComputerReplies: 0Last Post: 22nd Apr 2008, 12:47 -
What Is A Good File Type To Edit In iMovie?
By duraysteeus in forum EditingReplies: 1Last Post: 13th Apr 2008, 02:22 -
virus internet suites and video capture advice sought.
By DBenz in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2007, 20:19
