Recently I have converted some of my RMVB into AVI by folowing the guilde "How to convert RM/RMVB to AVI or MPEG1/2 (https://forum.videohelp.com/topic289872.html)", the conversion wasn't a problem and it seem to work fine when i review it at my computer.
The problem arose when I wanted to burn that converted AVI to DVD by using 'Window DVD Maker' from Vista, the end result was top half of the TV screen was video and the bottom half of the screen was blank green colour screen. However the main menu looks OK.
Could any one please kindly advise me on the problem and way to rectify it.
Thank you.
A lot would depend on what format of 'AVI' you had. There are many, many types of video that could be called 'AVI'. AVI is just the name of the container, not the format.
WDM, at best, is slow and unreliable and not likely to handle many file types. I would use a different converter program. Maybe the freeware FAVC or similar. Others here: https://www.videohelp.com/tools/sections/all-in-one-dvd-converters
You can also drop your AVI into Gspot 2.70 and post a screenshot of it here. That might show a problem with your file. https://forum.videohelp.com/topic271697.html
And welcome to our forums.
Thanks redwudz,
however I still couldn't solve my problem. I tried to use FAVC, it failed. I tried to follow https://forum.videohelp.com/topic271697.html to post a screenshot, but my 'print screen' button doesnt responded, I couldn't captured the screen to show.
Well, as ar as I remembered, I converted my original RMVB file thru VirtualDubMod, I selected Xvid MPEG-4 as my video compression, Mpeg Layer 3 as my audio compression. The converted AVI file worked fine on my media player. It only came out wired in my final DVD while I buned the DVD or convert it to WMV with my Window Movie Maker. -
Aside from you experimenting with different tools to perform the avi to DVD conversion (check HOW TO: Convert and choose avi > DVD). We won't be able to help much without seeing the file specs. The problem could be a result of the original conversion or just a poor avi to DVD conversion.
Google is your Friend -
If authoring as VideoDVD was your ultimate goal, you should read what applies to the "or MPEG1/2" part of the guide. No sense in goingOriginally Posted by lotususer
RMVB->AVI->mpeg2
if you can go
RMVB->mpeg2
/Mats -
Thanks all of you.
I got the problem solve. It wasn't the conversion, It was my vista than causing problem. Some how when I tried to burn my AVI file into DVD by using another computer (with windows XP) it worked prefectly, so I guess it might be some software corrupted in my vista.
Thanks again for the helping.
Convert AVI and burn to DVD: problem w/ NERO
By jimbo213 in forum Video ConversionReplies: 3Last Post: 3rd Aug 2009, 05:10 -
Burn Already converted MPEG Movies To DVD
By killagoob in forum Newbie / General discussionsReplies: 1Last Post: 19th Apr 2008, 21:11 -
Audio problem on converted DVD
By ssalim in forum Video ConversionReplies: 4Last Post: 26th Jan 2008, 19:07 -
Having problems getting a MPEG Video Wizard converted/edited DVD to burn
By editup in forum Video ConversionReplies: 18Last Post: 15th Oct 2007, 23:40 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
