I need the subtitles for the movie, "Scrooge", 1970, staring Albert Finney. The subtitles for this version is not on any subtitle data base, so after you extract them, could you please upload them to http://www.opensubtitles.com/
so other people can download the subtitles. To extract subtitles, I recommend using VSRip, or similar software and extract out the closed captions. It takes about 3 minutes to extract the subtitles. You effort will be appreciated because I plan to show this movie to students who are learning English.
Try http://www.allsubs.org/subs-download/scrooge-1970-2-5-fps-1-cd-en-divxforever-eng/104853/
You'll probably have to sync this with your version. Subtitle Workshop has some good tools for adjusting times (Edit/Timings/Adjust; see the Help document for details). -
Thanks. I thought I checked all the data bases. Guess I missed that one.
The subtitles work perfectly.
Does anyone know how to extract subtitles from .ts?
By ALUOp in forum DVB / IPTVReplies: 48Last Post: 27th Jul 2022, 00:39 -
How to extract subtitles from .wtv?
By devilcoelhodog in forum SubtitleReplies: 0Last Post: 12th Jan 2012, 20:44 -
Extract subtitles from .ts
By anchonio in forum DVB / IPTVReplies: 9Last Post: 16th Apr 2011, 04:07 -
Wrong subtitles from local disk but ok from dvd media
By aleangleico in forum Software PlayingReplies: 2Last Post: 25th Aug 2008, 11:26
