hi,
I did a search on the board on this subject and I could not really find anything definitive on the board or for that matter on the net... for what i was looking for..
now from everything i read sli graphic cards (a dual configuration) appears to really give high performance in gaming.....
my question though is about does it help you in video editing? Can it really help you increase your editing performance? my thoughts are that it doesn't but I can't say for sure....
does any one have any experience with these sli card and video or imaging editing? and what your thoughts
My understanding is that a graphics card will only assist in decoding not in encoding. So if you have high def video files you want to playback a faster graphics card will help in that matter to take the load off the cpu.
For video ENCODING - in otherwoords processing a file into a divx or turning a divx/avi into a dvd compatible mpeg file - is mainly a task for the cpu.
If you want to encode faster than you are better off with more ram and a faster processor. If you want gaming than yes a faster graphics card is always wise. But it will only aid in processing playback of files not in encoding them.
I may not know the specifics of the technical nature of this but that is what I have gathered from my readings over the years on this website.
Others are more than welcome to clarify my answers.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
OP did say editing.. in which case you would have to presume either raw footage or mpeg2. I would say that yes it will help but really the difference is marginal (the card can do hardware decoding of mpeg2) maybe in the order of 5%. For the same money faster and larger hard drives would be a far better solution. This is when RAID drives really show their stripes. Or a dual cpu setup. More ram is always a goer as well and will give far greater bang per buck than Dual gpu's
What you need is a video editing card, they are expensive and usually work with software directly but do make a vast increase in what can be achieved in terms of time
If software has been written to use the GFX card GPU then yes you will notice a big speed up, BUT only if the software is capable of using it, otherwise you won't see much of an increase
Canopus is a main supplier of video hardware editing and software -
As noted above, you would need a video editing specific card. Normal cards in SLI mode aren't going to make any difference. Unless you have a budget for an editing card, then your main concerns are your data path (MB, cpu, RAM, HDD).
Google is your Friend -
Actually the hardware editing cards like the Matrox are only going to offer a vast increase if you're working with HDV or HD formats. Most modern systems have enough CPU power to handle the video work on the chip rather than on seperate hardware. For the cost of one of those cards your money would be better spent on a good CPU and platform.
As to the OP the video cards increase gaming performance because they take the 3D rendering off your CPU. Unless you're using 3D effects in the editing process of your video (transitions and such done pre-render) then they may help you out but again the money is better spent elsewhere. Video is 2D and since you are usually (hopefully) working with rough video, likely in DV format, the hardware MPEG2 decoding present on some video cards won't really help you until you've encoded it to that format and are simply playing it back. Besides, most consumer cards with this hardware don't really work with most editing apps, only playback apps like VLC or WMP because they utilize the card's proprietary codecs instead of their own.FB-DIMM are the real cause of global warming -
HI,
I just want to thank all you guy's you gave me more info than i have found in the last week or so of surfing...... again thank you very much for your informative information
Video streaming Online graphic
By prissen in forum Video Streaming DownloadingReplies: 0Last Post: 17th Jan 2012, 07:12 -
New "editing box", need advice on best use of multiple video cards.
By jaybird in forum Newbie / General discussionsReplies: 0Last Post: 10th Apr 2011, 22:16 -
Re-editing digital on-screen graphic on MPEG files saved from DVB-T
By ANOther1676 in forum EditingReplies: 3Last Post: 17th Dec 2010, 18:23 -
Video Graphic Error-- Unsure of the Cause
By Blue_Leader in forum Newbie / General discussionsReplies: 0Last Post: 10th Dec 2009, 18:15 -
best silent graphic cards with hdmi+dvi out and hdcp support
By deejay.2001 in forum ComputerReplies: 5Last Post: 13th Jan 2009, 15:01
