    Jan 2008
    I've been using Pinnacle Studio v10.7 for rendering and editing of DV. However, I'm having trouble with the large size of the AVI file. What programs (hopefully free versions) can I use to convert it to a smaller mpeg file? Once converted what program can I use to burn the mpeg to a DVD?
    USA
    You need a MPEG-2 encoder to convert to that format, then a authoring program to create the DVD structure.
    There are several freeware encoders, try HC or Quenc. For authoring, GUI for dvdauthor works well and it's also freeware. Or you could try a all in one converter like FAVC that might be a little easier and still give you good quality.
    If you aren't familiar with the DVD structure, format and specifications, I would also take a look at 'WHAT IS' DVD to the upper left on this page.
    And we have many guides available. 'Convert and Author' would be some to look into under 'HOW TO'. Each program listed in our tool pages also have guides referenced at the bottom of the pages.
    And welcome to our forums.
    Jan 2008
    Thanks for the welcome and helpful tips.....
  4. Mod Neophyte redwudz's Avatar
    USA
    Since you are new here I decided not to issue you a warning card for multiple cross posts. But any more will get you a card. Please read our rules before posting. https://forum.videohelp.com/viewtopic.php?t=124514
    Moderator redwudz
    Jan 2008
    Sorry about the multiple postings, first time forumer......
  6. Originally Posted by mc-help
    AVStoDVD will do all jobs you need (convert/author/burn).
    Bye
    MrC
    AVStoDVD Homepage
  7. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    ...and keep the video in DV format until you're done editing. Then, as a last step, convert to DVD specs MPG and author.
    /Mats
