I used WinAVI v7.1 to convert a 1hr30mins AVI file to DVD format (VOBs etc), then burnt them to a DVD with Nero. The resulting DVD works fine on my DVD recorder and computer, but when my brother tries to play it on his DVD recorder or Playstation 2 the picture is black and white and the sound is really bad. This has happened before with another DVD I've tried. Does anyone know what might be causing this, and have any ideas as to how to fix it?
Hmm, that could be it. I set the output and aspect ratio to AUTO after all. I'll try that, thanks!
Edit : Actually, do you know of a program I could use where I could put the DVD in the drive and it would tell me if it was PAL or NTSC? -
Most players will have an option to show the details. 720 X 480= NTSC. 720 X 576= PALOriginally Posted by ianpwilliams
Burnt DVD with vob problem (not playing on computer)
By lamaddvd in forum Newbie / General discussionsReplies: 7Last Post: 17th Feb 2009, 14:28 -
ARE THERE DVD / BLU-RAY Players that PLAY 720P DIVX FILES FROM BURNT DVD'S
By likesmeso in forum DVD & Blu-ray PlayersReplies: 3Last Post: 27th Nov 2008, 08:10 -
Audio distortion (clipping) on computer drives/players but not dvd players
By Left/Right in forum AudioReplies: 2Last Post: 5th Nov 2008, 19:21 -
Burnt DL playback question on DVD players, Edit: fixed
By WBFAir in forum DVD & Blu-ray PlayersReplies: 6Last Post: 23rd Jul 2008, 10:02 -
dvd burnt using avid wont play on some players
By cheesypuffs in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2007, 09:01
