    Jan 2008
    Hi I would like to be able to add text to a single frames in a movie. I have several movies that I watch all the time and would like to add text as a form of hypnosis to help me stop smoking. A friend tells me Im talking about subliminal messaging. Is this possible and what do I need. Many thanks in advance for any help.
    dogberry578
  2. Member Cornucopia's Avatar
    Sure you can do that. AVISynth and Virtualdub can do that with sub/logo/txt effect overlay plugins, plus just about any standard NLE. It's just a matter of narrowing down the timing of your "effect" from the normal ~1-5 sec "transitions" to just 1 frame (or just 1 field). Note: this will be very tedious.
  3. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    Here's THE solution for AviSynth:
    LoadPlugin("...\ApplyEvery.dll")
    AVISource("...\video.avi")
    ApplyEvery(25,"""ApplyRange(0, 1, "Subtitle","Smoking kills!",350,250,0,0,"arial",40,$ff3366,$0066ff,5)""")
    Plugin here:
    http://avisynth.org/stickboy/ApplyEvery.zip
    I tested it on a 720x576 clip, 350 and 250 here are absolute x/y positions of the writing. Since ApplyRange should be used inside, you can't remove any parameter even if you want its default state. Begin adjustment with only changing for your paths, be careful.
  4. Member vhelp's Avatar
    Mar 2001
    New York
    Yeah, ~!~ Happy New Years ~!~ guys
    Anyway.
    That just so happens to be one of my favorite Scrooge, by Albert Finney. I do like some of
    the other old'es too, cause they do have their place in the history of ERA's and things, but
    this one is my childhood favorite. Yeah, he did a great job in the adaptation. I ddin't realize
    he did many other things -- no wonder he looks so familiar on tv. Anyway.
    Also, I didn't know that there was a consortium of Subtitles that one could actually Download.
    Its funny, cause just the other day, AMC had air'ed Working Girl and they posted
    their DVD TV comments (or whatever they call them) in subtitles, and I thought, 'what a great
    way to add this in as a -special bunus feature- or something, in an upcomiing project for this
    movie.
    Unfortunately, I ran out of Fuji VHS tapes and I couldn't record it. I think its one of those,
    once in a life time, for these broadcast, so I know I can not expect it to come back on, later.
    Anyway.
    Still, it would have made a great (long and drooling) project. After recording it, I'd've captured
    it; and laid it out on a time line; and captured only the bottom portion of the video, to pull out
    the white text; and then post-process it for better color separation; and then run it through a
    OCR or something to get the text into an actual text file or something like that. Well, that's as
    far as I got in the idea for AMC 's DVD TV special features like this. Course, then afterwards, I
    would have put text subtitle text into an actual clean video where its not so masked as
    it was on AMC 's broadcast of that movie.
    Q: I'm sure there's no place for one to download these ??
    Alex_ander, your plugin (if that's yours) may come in handy at a later time. Thanks
    for sharing the mini-micro guide on its usage, here !!
    Cheers,
    -vhelp 4491
  5. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    You can do it as a subtitle.
    Create it manually in Subtitle Workshop; or if you want a lot of lines periodically, make it in say, Excel. Then you could experiment with different fonts, change the duration, colours, etc easily, and turn it off if you just want to with the movie.
    Jan 2008
    Hiya People
    Thank you all so much for your time and effort to help me out its very much appreciated.
    Thanks again
    Chris
