Results 1 to 10 of 10
    Apr 2003
    Hi all
    I have nero 8 (latest) and 3 DVD burners, all SATA. When I try to burn a CD, nero hangs at 'checking discs.' Any Ideas??
    Core2 Due 6750, 4 GB Ram Windows XP Pro with all the latest updates.
    I uninstalled and reinstalled nero. Worked once, then hung again.
    Brainiac
    USA
    Check the Nero burn log. It should have more information about the error. And you might try ImgBurn. It also works for CD burning.
    Nov 2002
    Every version of Nero that I've owned does that so I turn that feature off. Both my burners use smart burn so I don't worry about getting a bad burn on a CD. Burning a DVD is a different story and I don't trust that task to Nero.
  4. Member Marvingj's Avatar
    Apr 2004
    Death Valley, Bomb-Bay
    Nero usually have updates concerning patches to fix those problems but they are very, very slow......
    http://www.absolutevisionvideo.com
    BLUE SKY, BLACK DEATH!!
    Apr 2003
    I disabled the check disc function. All is well. Thanks!
    Brainiac
    Jan 2008
    Uruguay
    I have the same problem nero 8 (latest) and 2 DVD burners, 1 SATA, 1 IDE.
    When I try to burn a CD or DVD on IDE Drive i have no problem but if i try this in SATA, nero hangs at 'checking discs.'
    I uninstalled and reinstalled nero. i used the nero cleanup tool and reinstall.
    I disable the "check the correct disc format before running' option in options---> misc tab
    The problem still happens
    Me
  7. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Me
    Have you used this drive successfully with any other burning software? You may be having issues with the SATA controller on your MB supporting your burner (not all of them do).
    Google is your Friend
    Jan 2008
    Uruguay
    The burner works well with other software like roxio easy cd creator or with Windows media. The problem is with Nero.
    Apr 2003
    Update!
    Nero started acting up again. I tried to burn a DVD and CD and it hung at Checking Discs. I let it sit for a while and it started the burn! It works, but it takas while to START the burn!
    Brainiac
  10. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Could also just be another feature (bug) in the new software. I'm still using v6.x myself without any problems. When version 7 was released the forums were flooded with complaints/problems. I wouldn't expect v8 to be any different.
