Do you guys feel it is better to download and do your editing on avi's or just download mpeg's or convert your avi's to mpeg and then do your editing and burning
as avi's are usually smaller files it's usually easier to edit them (the computer takes less time...)
An "avi" is just the file extension of any number of audio-video stream formats. For example an avi can contain uncompressed video, MJPEG encoded video or as commonly found on the internet, DivX video.
Regardless of the extension, you should always try to do the editing on your source video as video quality will undoubtedly be lossed on conversion to mpeg.
Where to start? I'm a amateur photographer and I want to start out in video
By James Wright in forum Newbie / General discussionsReplies: 14Last Post: 3rd Jul 2015, 14:12 -
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 12:12 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 20:00 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
