Hi
I have a HP DVD 940i on winXP
I have wrote a few dvds from downloads
all seem to play fine till lately
this last one my comp says drive is empty, tried factory DVD plays fine
but my Sony DVD player plays it / it's capable of playing either NTSC or Pal
I was wondering if some how I could have wrote it in pal format
and if so how do I tell and how do I get the writer back to writing NTSC
I checked and my DVD writer is set to Region 1 but it also says I only have 4 changes left
I thought I read you could change it 5 times ?
also I have a small TV with builtin DVD player lately it says Wrong Disk when I put in a standard DVD but it will play all the DVDs I have wrote lately
am using Nero 6 OEM version
	Are you using ulead dvd moviefactory to make the dvds? You can set PAL or NTSC in most dvd author/converter tools.
 And region coding has nothing to do with PAL or NTSC and home burned dvds has usually no region. If you want your dvd writer region free for dvd playback you can use anydvd or dvd43.
	I used WinAVI to convert to DVD formet
 then I used Nero to write it
 I can not find a way to check in Nero
 what I always thought it didAnd region coding has nothing to do with PAL or NTSC
 ok so now I really lost
 ok installed dvd43
 I still can not read any DVD I have writen lately
 but can I wrote a while back and also the first couple I wrote with this writer
 this writer is less than a year old
	Since you are performing conversions, I assume you are using source files such as avi. Since the final output is viewable on your Sony player, then the conversion and the final dvd are likely fine.
 Using different conversion software and/or burning software would seem irrelevant at this point because the final product is already usable.
 My first thought would be that your burner is failing. Although why it can recognize and burn blank media, then not recognize the burned disc is a bit odd. I've had burners in the past stop recognizing burned media, but they were often bad burns.
 Region coding is a way of marking a disc to prevent playback in other areas of the world.
 NTSC and PAL (check the glossary) are different video formats (which use different resolutions and fps).
 Regardless of the region code (which doesn't exist on a disc that you burned yourself) or the video format (which may vary by the software used), a PC should be able to read the discs (PC's don't care about video format).
 Open my computer or Windows Explorer, then insert the DVD. Does Windows recognize the disc? Can you view the files on the disc? If the answer is no, you have a hardware (burner) issue. If the answer is yes, then you are likely having a software issue.Google is your Friend
	That is the problem.Originally Posted by TechJD
 I suggest you make backups from your own originals.
	Sorry for the long delay in responding
 turns out Krispy Kritter nailed it Writer was failing I got a replacement the HP 1040i and it can read all the disk I have wrote
 thanks all for the responces
  Realplayer files to another file format or dvd formatBy vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 13:12
  Converting raw DV format into a quicktime or MPEG formatBy Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 21:00
  Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegXBy bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 10:15
  Converting from DVD format to playable on MAC format...By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 09:21
  Convert Coreldraw file format(cpt) to some other format like tiffBy mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 11:38
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
			![[_chef_]'s Avatar](customavatars/avatar30571_1.gif)
