i want a PC to encode video to DVD player format, then burn it.
I don't want to wait long for the dvd to encode and burn, i also don't want to spend too much money.
im looking at less than a grand... alot less if i can.
i asking for advice on mainly: CPU, RAM, and MOBO.
thank you in advance.
Get a barebones system for $150, then add RAM, a CPU, and a Hard Drive with a DVD Burner
Barebones $150
http://www.newegg.com/Product/Product.aspx?Item=N82E16856110081
CPU $170
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115030
Hard Drive $120
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148288
RAM $45
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211066
DVD Burner $30
http://www.newegg.com/Product/Product.aspx?Item=N82E16827129018
That's around $520 Total. Add a low end video card for $50 if you have a flat screen and need DVI -
Get an 8 Core. The Mac Pro can run XP and only costs $4500
You can see the performance scores for different processors here:
https://forum.videohelp.com/topic336716.html
http://www.techarp.com/x264_Benchmark/gfx/results_intel_big.gif
Yes, a Quad Core will be faster IF your encoding software can take advantage of it. The size of the L2 cache is very important. Your proc should have 4MB minimum, regardless if it is Duo or Quad core. For a quad, the cost will be more and you'll need faster RAM and a better power supply. You'll be getting closer to your $1000 limit.
Good Quad Core Mobo- DFI Blood Iron
http://www.newegg.com/Product/Product.aspx?Item=N82E16813136038 -
what kind of difference are we looking at. I could live with under or at an hour of actual encoding and burning time.
Under an hour? That would mean 60fps encoding speed on a 1pass encode. You'll want a high end Quad core.
Accept 1.5 -2 hrs to make it in your budget.
Look at the column on the right - "Time to Encode 2hr movie"
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 14:46 -
Need to Remove Logo for a set time at a set place.
By Ensign in forum EditingReplies: 3Last Post: 11th Sep 2009, 15:39 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 14:11 -
x264, set quantizer to 10 and vary keyinterval to reach set target bitrate?
By frifox in forum Video ConversionReplies: 6Last Post: 20th Feb 2009, 15:59 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 00:31
