Any time I try to watch a streaming video on any place (Windows Media Player, Stage6, etc) the video seems like it is zoomed in. I can hear the sound sound perfectly, but the video seems zoomed, or is just black. Please hlep.
Sounds like a player (WMP has zoom options) and/or codec issue. The first step in troubleshooting would be to identify the type of video that isn't working (wmv,mov,flash, etc.). After you know the file type, then you will need to install/reinstall the codec for that type of file.
And this isn't a media issue. This should be moved to the Software Playing forum.Google is your Friend
Problem trying to upload a stream....... I get video but no audio
By True Colors in forum Video Streaming DownloadingReplies: 0Last Post: 15th Oct 2011, 19:06 -
How to stretch longer audio stream to a shorter video stream ?
By ralf07 in forum AudioReplies: 9Last Post: 31st Aug 2011, 23:42 -
Problem converting from MPEG Program Stream to Transport Stream
By vivajam in forum Newbie / General discussionsReplies: 5Last Post: 24th Jan 2011, 05:40 -
RAW blu-ray 264 video stream to MP4 ? Problem
By scoobdriver in forum Blu-ray RippingReplies: 7Last Post: 18th Nov 2008, 19:19 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 04:27
