Do i need an engineer degree or something to make it work?
What i want to do is cut a part of a .ts file & keep only one audio track( currently i have 3 audio tracks: german/english/german ac3)
Enlighten me please
What i did so far is: selecting the start&end of what i wanna keep >cut selection
then i don't get it
Results 1 to 12 of 12
after cut selection click on "save as" at the end of the same row of buttons as cut selection.Pretty sure you will have to use another application to remove the audio if your using VideoRedo,if you are using VideoRedo TVsuite you can select a stream by clicking on Tools/select stream the selected stream is highlighted blue.
I have video redo plus (trial version)
I can select the audio stream i want apparently but when i wanna SAVE the part i have "cutted" it don't work; it's taking the whole file not the portion of it i have selected.
i followed your advice, i picked up "save as" in near "cut selection"
i don't get it.. -
Make your Sel. Start and Sel. End points
Click Trim Unselected
File>Save Video As... -
looks like it's better now when i use this option thanks for your input powerpc
*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
I am working with videoredoplus. i want to cut the adds. for that i open the video in VRD. clik on add detect. it detects the add as marking with red arrow marks. the question is how can i delete the marked up adds in one step. i couldnot find option for that. to delete the adds I am selecting each addpart and --- cut seletion and then save as...it saves avoiding one add. I am not able to select all the addpart at the same time.when i select the ---sel start and sel.end of one part, then if i move to another part the first one is left without selecting. the shift key is not working in this case as we select multiple columns in microsoft excel.Is it possibe to delete all the adds in the file in one step? where i can find the option.plz ...with a screenshot if possible.
another question with videoredo plus is----- I want to get a particular portion of the video opened.It plays showing the frame numbers.To get a required frame number--- is there any option for seek? the only thing i can do is to move the cusor to the required portion. -
Go to beginning of unwanted commercial segment(s), click Sel. Start
Go to end of unwanted commercial segment(s), click Sel. End
click Cut Selection
repeat
repeat
repeat
what about the second part of my question. plz put some light on it. can i seek a particular frame number in vrd?
Your welcome; as for the second part of your question, I can see no ability at present to seek a particular frame number. The developers of that program seem to welcome feature requests on their forum boards.
http://www.videoredo.net/msgBoard/forumdisplay.php?f=9
If it is of any help and you may already know, you can toggle from frame to time view under the view menu option. You should also be able to seek to time under Edit > Go to Timecode.
VideoRedo TV suite 4
By nirbhayn in forum EditingReplies: 0Last Post: 19th Jan 2011, 15:56 -
FLV / VideoReDo Plus
By oz_surfer in forum Newbie / General discussionsReplies: 1Last Post: 18th Jan 2009, 03:42 -
videoRedo Plus
By natty in forum Newbie / General discussionsReplies: 3Last Post: 14th Jun 2008, 09:38 -
VideoRedo->DVRMS Issue, VideoRedo->MPEG2 Fine, Please Help
By tbrnet in forum Video ConversionReplies: 0Last Post: 10th Jan 2008, 16:43 -
Problems with Videoredo
By Helltrain in forum Video ConversionReplies: 2Last Post: 21st Dec 2007, 13:33
