I have been using DVD MF 2 on XP for years.
I just picked up a new PC with Vista and loaded MF. It now has a problem that chapter insertion doesn't work. All options in the add chapters menu are grayed out and non selectable. Otherwise it loads and will author the DVD ok.
I'll probably end up getting a new version. I am going to give the version 6 trial version a try. It's $79 to purchase.
On ebay, version 4 is available for under $25, so I like to know if anyone has sucessfully used version 4 with Vista.
BTW, I tried using the Windows DVD maker that comes with Vista, but from what I can tell it doesn't support adding chapters. Please correct me if I am wrong.
If you check the Ulead site (and you are trying out the latest version) then you will see that only from version 5 that Vista is supported.
But there are problems and not being a Vista user I do not know whether they have now been solved.
I suggest that you register at the Ulead forum as there are guys there with plenty of hands on experience.
Ulead DVD Movie Factory 6 Plus
By orientaldragon in forum Newbie / General discussionsReplies: 8Last Post: 2nd Apr 2011, 09:48 -
By Ragamuffin in forum Authoring (DVD)Replies: 3Last Post: 6th Oct 2009, 13:22 -
Ulead DVD Movie Factory...
By mmitchell_houston in forum Authoring (VCD/SVCD)Replies: 225Last Post: 23rd Oct 2007, 11:59 -
By koberulz in forum Newbie / General discussionsReplies: 10Last Post: 26th Jun 2007, 08:14 -
Ulead DVD Movie Factory 5 Plus Help
By sootylfc in forum Authoring (DVD)Replies: 3Last Post: 21st May 2007, 19:20
