Hi! I have a question that I am dealing with:
I have the Canopus ADVC 300. I want to get some Hi8 analog tapes onto my computer using a digital8 camcorder.... I'm wondering if its possible that using the S-video output on the camcorder; feeding S-video into the canopus; then outputting from Canopus to the computer with firewire...could this yield better quality results than using the firewire connection directly from the camcorder into the computer? I'm very concerned with getting the best image and sound quality possible.
I've also read the threads about black levels and the 7.5 vs 0 setup thing, and was wondering how that would be affected either way?
Thanks!
Just go straight from the Digital8 to the computer - there's no advantage to going via the Canopus.
As Johnny says, just use the Firewire output on the camcorder straight into your computer. The analogue information on the tape with be turned into DV in the camcorder and transferred to the computer. This has got to be better than outputting analogue video from the camcorder with the inherent losses involved in an analogue to analogue connection, turning it into digital data in the Canopus and then transferring.
Reading 8 mm and HI8 tapes in Digital8?
By tentate in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 28th Dec 2009, 10:58 -
Digital8 to DVD Quality Issue?
By robbieturner in forum Authoring (DVD)Replies: 12Last Post: 8th Sep 2009, 05:23 -
Sony Digital8 Camcorders
By k2skier in forum Newbie / General discussionsReplies: 1Last Post: 15th Jan 2009, 13:10 -
Erasing Digital8 tapes
By skieffer in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Jan 2009, 12:24 -
How to use Canopus VideoFx with Canopus let's edit2
By perfection in forum EditingReplies: 1Last Post: 25th Sep 2007, 03:56
