Does anyone happen to know what the range of dvd program codes for the DVP5982/37 while using the TW hd cable box remote (Scientific Atlanta, I think-8400?)?? TIA.
I assume you mean remote codes for programming hardware into the cable remote. A good place to start is their website and you will need to know the model number (maybe won't work). http://www.timewarnercable.com/Corporate/answersondemand/remotecontrol/chooseyourremote.html
Google is your Friend -
Yes, that would be correct...cable remote program codes. I think I found 3 codes that might work for the SA 3250HD box and the DVP5982/37, but the remote itself shows up no where (UR5U-8800L-TWR). I'll have to try these codes later (2201, 2228, 2230). Some times the box won't accept a 4-digit code...only 3, but hopefully these will work.
Phillips DVP5982 vs Phillips DVP5992?
By jarko in forum DVD & Blu-ray PlayersReplies: 4Last Post: 12th Jul 2008, 13:41 -
Can't play Xvid on my Philips DVP5982
By rreeze in forum Newbie / General discussionsReplies: 10Last Post: 20th May 2008, 10:53 -
Philips-DVP5982 HDMI Connection help
By jimtnc in forum Newbie / General discussionsReplies: 4Last Post: 22nd Dec 2007, 05:52 -
DVP5982 with USB hub?
By Fearnot in forum DVD & Blu-ray PlayersReplies: 3Last Post: 12th Dec 2007, 15:44 -
Philips DVP5982/37
By exster in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Sep 2007, 21:28
