    Jul 2007
    Hello everyone, I believe this is an HD DVD movie. Not sure. I do know it is an image file. jagbo was helping me in the other section. My question is, how do I get an .img file into a regular format? I assume that would be a start and then from there take a look at gspot for the codecs so I can encode from HD to regular XviD? Am I right or wrong? Thank you for any replies.
    Apr 2004
    Miskatonic U
    What you have is a disc img. Mount it with Daemon Tools and you can access it like any other disc, and do whatever you need to it.
    Read my blog here.
    Jul 2007
    I just took a look at Daemon Tools and I think in order to mount it I need an HD drive? Is there anyway to work around that and mount it without burning?
    Apr 2004
    Miskatonic U
    The whole point of Daemon Tools is that it pretends to be a drive so you don't need one - it is an emulator. Interestingly, while the Tools page for Daemon Tools says it supports img files, the actual site doesn't have them listed as a possible.
    You might also look at MagicDisc (magicdisc.net) which is another free Virtual Drive application, and does explicitly state it supports .img images.
    Based on the name of the file, I suspect you actually have a DVD image. How big is it ?
    Read my blog here.
  5. Daemon Tools supports the .img format. Following guns1inger's advice is how you deal with them.
  6. Banned
    Freedonia
    You are almost certainly wrong about this. What makes you think so? While in theory it is possible to burn HD-DVD movies to dual layer DVD discs (the format specifically allows this), there are no commercial examples of this. Since there basically aren't any HD-DVD burners either at this time, an IMG file of a true HD-DVD would be pointless. The only exception I could see is if someone took a high def TV recording and authored it to DVD dual layer size in HD-DVD format (this is possible and I have an example of such a disc), but these discs are rare and probably you don't have one.
    If your IMG file is 4.5 GB or less, I can promise you that it's not HD-DVD. The format requires the use of DVD dual layer discs at a minimum.
    Apr 2008
    Use MagicIso to extract the.img file
