I recently bought a ZR 800 canon cam which I am starting to use now. I inquired about the cam on this forum a while back and decided to make the purchase based on the positive replies I received here . I am quite green at editing I really need some help in finding an easy to use editing tool. I want to make home movies and burn them to dvd. I tried Windows Movie Maker but I wasn't that impressed with the results ( the final result was very pixelated). I was going to try Vegas 8.0(seemed like a great program), but I don't have a lot of time to spend learning Vegas and DVD Architect. I have a Pentium 4 windows xp machine 2ghz with 2 gigs of RAM. I am looking for something to try that doesn't have a large learning curve and produces decent videos. I am willing to buy software as well. I would like to try out some programs before I purchase them though. Any leads or help would be appreciated...
Peace
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I started out using Ulead Video Studio for editing and TMPGEnc DVD Author for DVD creation. I think Ulead has a DVD authoring software also but I've never used it. Ulead and TMPGEnc are both fairly user friendly and not too hard to learn and they both give good results.
Windows Movie Maker works very well...
!. you HAVE to save as a DV-AVI...(13 gig per hr)
2. Use another program (ie: Ulead Movie Factory..or others) to burn to DVD..
3. Unless you have VISTA then forget above...
Video editing software that supports importing video with multiple audio?
By elgy in forum Newbie / General discussionsReplies: 5Last Post: 15th Nov 2011, 19:32 -
Webex recording changes video to side panel. Can I edit with video editing?
By Teenotes in forum Newbie / General discussionsReplies: 0Last Post: 2nd Jul 2011, 12:32 -
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 01:29 -
Video editing programs letting you create .m2ts files with VC-1 video?
By justin0324 in forum Authoring (Blu-ray)Replies: 1Last Post: 17th Mar 2009, 22:24 -
Is there a video card that can handle both: gaming & video editing?
By randyannie in forum Newbie / General discussionsReplies: 11Last Post: 20th May 2007, 15:50
