Results 1 to 9 of 9
Did you transfer them to your computer or capture them? Your camera can record in 4:3 or 16:9, so you will need to ensure you actually used 16:9. Also, according to the manual (p. 75), the camera records video at 320x240 or 160x120.
Google is your Friend -
It's simply because WMP is savvy enough to know when a DV AVI file is widescreen or not. Older versions of WMP (9 and earlier) do not display the correct AR either.
Microsoft's DV decoder puts the right information into the media sample that it sends WMP for each frame. WMP bothers to read this information whereas other media players don't. -
I couldn't find any other references to resolutions used by that camera. Aside from that, since you are capturing and not transferring, it's irrelevant anyway. Your capture program should be setting the AR flag within the files.
Sorry, what is the difference between transferring and capturing? I thought it was the same thing.
They mean the same thing. Some people argue one is correct and the other isn't and the other way around. Others say "importing", too.
Basically, they both mean getting the video from the camcorder to the computer.
Don't worry about which is "correct" and which isn't. It's like discussing politics and religion. -
I wasn't implying one was "correct".
Transferring implies moving the file from a device to the PC. Like copying pictures from a digital camera.
Capturing would be the process of playing the video on the camera and recording it on the PC.
Aside from that, most cameras come with software for getting the pictures/video from a camera onto a PC. Have you tried the offical software? It will at least rule out software as cause of the problem.Google is your Friend
Cedocida - "Jittery" playback on some media players/DVD players
By BertRito in forum Newbie / General discussionsReplies: 11Last Post: 4th Aug 2010, 20:20 -
Black screen with audio in all players except WMP
By charliei in forum Software PlayingReplies: 11Last Post: 8th Jun 2009, 19:42 -
Audio distortion (clipping) on computer drives/players but not dvd players
By Left/Right in forum AudioReplies: 2Last Post: 5th Nov 2008, 20:21 -
Playing AVCHD on plasma using WMP=wrong AR
By EliG in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 29th Oct 2007, 12:54
