hi , i have a mkv file that includes 2 audio tracks and 2 subtitles tracks, and it has 255 mb , i want to make it be like 180-200mb, i tried to do the following , extract all tracks with mkvextractGUI , then i converted the video to avi ,so the video in avi had 165 mb , i succeded in adding the audio track i wish but i cant add the subtitles...i lost like 5 hours searching and trying things , pls help
p.s it doesn matter the format to convert my goal is to make file weight 180-200Mb and get rid of unwanted audio track
Are you just trying to shrink file size? Only for PC play or standalone DVD?
When you have separate streams (video, audio, subtitle), just select the ones you want to keep and remux them with avimuxgui or mkvmerge to keep a mkv container
If you want to keep your re-encoded avi, you may have to convert your subtitle to a different format (like .srt) using subtitle workshop (depending on what the original format was) -
@ poison thank you master of video stream
, used the programs u said and it worked , thank you
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 02:45 -
mkv to avi with xvid4psp! It's killing me! Help pls!
By Ramazan in forum Video ConversionReplies: 1Last Post: 28th Sep 2011, 07:52 -
Xenon MKV Help Pls
By sikstik in forum Video ConversionReplies: 5Last Post: 13th Jun 2009, 12:50 -
Mkv to DVD9...Pls Help !
By john_triton in forum Newbie / General discussionsReplies: 2Last Post: 11th Oct 2008, 06:57
