Would anyone know a brand of VCR / DVD combo unit that doesn't require the use of composite video cables, but sends both, the VCR and DVD signal through the RF/coax outputs? *The video quality is irrelevant. *Thanks!
Probably nobody makes such a combo unit. However, Radio Shack and I'm sure other companies sell RF modulator boxes that typically take audio and either S-video or composite video inputs and output to RF. This is probably what you are going to have to get to do this.
From the way your question is phrased, I'd say that pretty much ANY VCR/DVD combo can do that. I have a GoVideo & a Toshiba, both VCR/DVD combo units, & both can output both VCR & DVD via the RF connector.
Stiiv -
Originally Posted by Stiiv
Most combo units share the inputs/outputs, so any model that you can find which has a coaxial output (the few I checked don't support it any longer), should work for you. A quick way to check is the look at the manuals online.
Google is your Friend -
What Krispy said. If you see the coax connector on the back of the unit, odds are that both signals are available from that output.
Stiiv
Best Dvd Recorder/Vcr Combo
By rosbif08 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 9th Oct 2010, 15:52 -
DVD Recorder/VCR combo
By tj1182 in forum Capturing and VCRReplies: 4Last Post: 1st Dec 2009, 20:52 -
DVD Recorder/ VCR combo
By whitemtntn in forum DVD & Blu-ray RecordersReplies: 9Last Post: 7th Aug 2009, 21:30 -
Best VCR OR VCR/DVD COMBO for restoration
By demonwarrior in forum Newbie / General discussionsReplies: 7Last Post: 24th Aug 2007, 02:02 -
Magnavox combo DVD/VCR/TV
By DSedon in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Jul 2007, 11:36
