I have a movie that is already burned and it cuts off in the middle and i have to click with the remote to the second half of the movie,i tried ripping it to my computer to use hjsplit to join the files but it would not doit since i think the files are in VOB format now and it's more then just two files it's like 8 now,is there a way i can make it 2 files again and then join them with a program to where the movie doesn't cutoff in the middle and i have to click the second half to finish?
I would rip them from the DVD into separate avi files with autogk. Then instead of joining them, I would author a dvd with TDA and add both videos to the same track so they played back to back. or author with convertxtodvd, again add both videos but select the "sequential playback" option so they play back to back. Then again i'm a noob so that may be a bad option.
Rip from the DVD - OKOriginally Posted by marioval
Convert to Divx with AutoGK - quality drop from needless re-encode
Re-encode to DVD compliance - second quality drop from needless re-encode
Re-encoding should be avoided whereever possible, especially if you have compliant footage to work with.Read my blog here.
Best free way to split or join .MP4 files?
By Nagashi in forum EditingReplies: 31Last Post: 16th Nov 2023, 00:16 -
split/join avi files without recompression
By Jan G. in forum EditingReplies: 3Last Post: 20th Dec 2008, 14:54 -
join & split m2t files
By shun in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 1st Dec 2008, 21:15 -
Cucusoft DVD to iPOD - Join/Split Files
By technologistau in forum DVD RippingReplies: 1Last Post: 16th Sep 2007, 05:49 -
Re-join single DVD-9 film split onto two DVD-Rs
By denti alligator in forum DVD RippingReplies: 11Last Post: 24th May 2007, 21:47
