Hi
I use vlc to play xvid files. Lately, I have started noticing artifacts .... like when there is a sudden action scene like somebody moving his hand then that path of hand movements seems to hang on for 2 seconds before it becomes
normal. Previously, I was using 17 inch crt monitor but now switched to 19 inch lcd viewsonic monitor. I dont remember if this issue started after I got this monitor or I was able to play normal on this lcd.
I tried bs player pro but with same problems..
My video card is fx 5200 but I am planning replace my machine itself instead of the card later on..
pls suggest !
Sounds like typical playback of poorly encoded files. Although unlikely, it could be codec related. Ensure you have the latest version of the codec used on your xvid files (you can check the files using Gspot) and playback with a player like MPC. VLC uses it's own codecs, so the only way to get it up to date is to ensure you are using the latest release.
Google is your Friend -
ok, I would try to play those movies on my laptop and check for the artifacts and let this forum know about it.
Xvid creates blocky artifacts! Help!
By david.dgc in forum Newbie / General discussionsReplies: 35Last Post: 18th Apr 2012, 12:27 -
Black blocks/artifacts when viewing XVID on TV
By skribby in forum Newbie / General discussionsReplies: 4Last Post: 21st Feb 2012, 08:48 -
Artifacts while playing videos on my laptop
By cd090580 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Sep 2009, 12:43 -
Problems playing Divx / Xvid files on Silvercrest KH 6508
By Onihoshi in forum DVD & Blu-ray PlayersReplies: 7Last Post: 11th Oct 2008, 15:18 -
Samsung HT-TX75 not playing my Divx & Xvid files
By danimaltron in forum DVD & Blu-ray PlayersReplies: 7Last Post: 19th Nov 2007, 20:02
