Hello folks I was wondering if someone could help me out with a issue. I am currently using Intervideo dvd copy 5 platinum. I am shrinking a dvd 9 to dvd 5 with just copying the movie only. I have problems with the dvd structure getting corrupt after it has been shrunked down to a 4. 3 gb or smaller file size. I have tried it with movies and also episode dvd's from tv shows etc. They are already decrypted so its not that. I have no problems with the files once I have them decrypted to my hd and they are fine in Intervideo dvd copy. I go through and select the shows I want and audio track I want to keep. I do this in custom mode and keep only the shows no menus or extras. It encodes them fine but the ending result with not work right as nero along with Ulead and other burning software including Intervideo will not give me a working result. Can anyone help me out with any suggestions. It comes up on Nero like incorrect file structure. I know quite a lot about shrinking dvd burning etc. I have tried all I can think of and do. Thanks for any help.
Eric
What is the output type from DVD Copy 5? If it is an iso, then Nero shouldn't be giving you an error. You could also try burning the output with another app, such as ImgBurn. Aside from that, it sounds like DVD Copy 5 isn't working properly and not creating a disc image that meets DVD spec.
Try other applications. DVDFab Decrypter and DVDShrink (among numerous other options) work fine for all media.Google is your Friend -
Hello I am not using intervideo to burn the file. When I am done going through the steps of what I want to keep in the movie I use intervideo to shrink it to dvd video mode not iso or anything else. When its done its in the video_ts format. When I go to use Nero to burn the video_ts folder it says the file structure is not correct and may not play. I don't know what to do to make it correct as far as the dvd file structure goes. I tried to rip the videos out of the ending result with ulead dvd movie factory and tmpgencoder and they all say the same thing. Incorrect file structure can not open. O well I will just try some other things and hopefully it will work. Thanks for trying to help me out.
Vegas 10 Platinum Problem
By REDRUMxINxTX in forum EditingReplies: 6Last Post: 26th Jan 2012, 18:53 -
SONY Movie Studio Platinum 10 rendering problem!
By EagleW in forum EditingReplies: 4Last Post: 4th Nov 2010, 17:52 -
Worth upgrading from sony platinum 8 to platinum suite 10?
By helper in forum EditingReplies: 0Last Post: 30th Jul 2010, 00:30 -
Getting audio desync problem when ripping with DVDFab Platinum 4
By godfist314 in forum DVD RippingReplies: 2Last Post: 8th Jul 2008, 13:50 -
DVDFab Platinum generic.xvid.mp3 audio problem
By JoeWillis in forum DVD RippingReplies: 0Last Post: 29th Aug 2007, 18:59
