Happy new years to all
Ive been making DVDs from all sorts of sources (for use at home)
eg: 5 or so avi(divx) files converted to DVD with menu's using convertxtoDVD.
then the audio_ts and video_ts files are then burned to Ritec DVDs using nero 7
when the disk is produced it will play on the dvd drive in the PC
and will play on my pioneer dv400k stand alone dvd player (with divx)
but will not get past the first episode on my pioneer dvr 330 dvd recorder also I have tried these disks
on friends DVD players and have only found One dvd player that the disks will play on.
some read the disk and like me will play the first episode only, then on the other episodes will start to jump around,stop start jam up or just not read at all..
So how do I make a disk that first of all will play on my pioneer dvr 330.
what do you think i am doing wrong.
I always burn on the lowest speed 4x on the ritec disks
and i always use DVD video settings on nero 7
Results 1 to 13 of 13
I would try new discs, Verbatim or Taiyo Yuden. I just had a problem where my RitekG05's would not produce a readable DVD on two separate players. I burned the same image on Verbatim +R 8x and it worked perfectly.
Two suggestions:
- Ritec (Ritek) discs are generally not good quality, the recommendation is usually to use either Verbatim or TY discs
- Since you've already generated the proper video_ts and audio_ts folders, just use ImgBurn in "Build" mode.
I've followed those two bits of advice and and no issues with playability.
Hope that helps,
Jim -
There is no substitute for good media and most burning problems are media related. Dump the riteks and get some TY or Verbs. I wouldn't use anything else. Bitset (also called booktype) it to DVD-ROM. Also, burn at the rated speed or in the case of 16x I burn at 12x. I don't know where this idea came from that slower is better, nonsense! Make sure you have the latest firmware for your burner. Do this and tell us how things worked out.
I love children, girl children... about 16-40
W.C. Fields -
YOU GUYS ARE QUICK
ricoman
"Bitset (also called booktype) it to DVD-ROM"
could you please explain this ...
in the mean time , Ill dump the ritek and look for the others
I ll be back with the out come
small question.. why ? are the disks just better built, have lower error rates or something like that..
Thanks again -
Ritek has low reflectivity.
There are burners which have a better success rate with Ritek than yours has.
In any case, the suggestions that you use stop using Ritek may solve your problems.
Why are you using Nero to burn the output of ConvertXtoDVD? The later versions of convertXtoDVD have a built in burning engine. -
Some DVD players, particularly older ones, are not compatible with +R media, so you can set your burner to DVD-ROM which "fools" the player into thinking the media is -R. I use Nero CD/DVDspeed, a burner utility to set the booktype. It is free: http://www.cdspeed2000.com/ make sure your burner shows in the dialog box, click Extra, then Bitsetting, then where it says "new setting" choose DVD-ROM and click Set. That's it. Some burners you have to set that each time you burn (LG comes to mind), others will keep it as the default after setting.
W.C. Fields -
No... it set's the booktype on +R's to DVD-ROM so it see's it as a store bought pressed disc 8)Originally Posted by ricoman
not a -R. -
I had that utility in nero so now its changedOriginally Posted by Noahtuck
but that is for +R disks
the ritek ive got are -R -
I dont know why, probly just used to nero thats all. and i dont always burn to disk straight away. i may try itOriginally Posted by oldandinthe way
my burner is a LG about 2 years old set at region 4 -
Yeah you can only change the booktype to DVD-ROM on +R's.Originally Posted by suomiaussie
Yep... the VSO burning engine in ConvertXtoDvd is good, i never had a problem with it the few times i used it, but i use ImgBurn to burn the resulting files also.Originally Posted by guns1inger
I just noticed the latest version i have does not let you choose between using NERO or the VSO burning engine ?
I know older versions did, or i'm missing something on the newest version....
Do all DVD players deinterlace DVDs made from mini-dv camcorders?
By granturissimus in forum Newbie / General discussionsReplies: 12Last Post: 16th Jan 2011, 21:01 -
stand alone dvd players that play .wmv or h.264
By scorpio291 in forum Newbie / General discussionsReplies: 4Last Post: 26th Jun 2009, 11:58 -
Magnavox MWR10D6 choppy dvd playback when using other home made dvds
By heatherval in forum DVD & Blu-ray RecordersReplies: 4Last Post: 27th Dec 2007, 10:59 -
*for all who use nero,and dvd wont play in your stand-alone*
By headstate in forum Authoring (DVD)Replies: 182Last Post: 24th Jul 2007, 03:00 -
HELP! DVD's won't play on stand alone players
By jessandjeff123 in forum Newbie / General discussionsReplies: 9Last Post: 7th Jun 2007, 07:59
