I downloaded a movie that is made up of 5 .mdf files, i.e. TITLE.mds, TITLE.mdf, TITLE.md0, TITLE.md1, etc. In order to burn to DVD, do the files need to be joined to one file, such as .iso? I discovered a program called "Split & Concat", which will join and split... but it apparently only joins the first 2 files (the 3rd, 4th files are ignored). Or can I simply drop all the files in Toast and burn without actually "joining" them??
Results 1 to 11 of 11
try reading through this-
https://forum.videohelp.com/topic208896.html--
thanks, I actually read that before I posted this. The problem I'm having is that "Split & Concat" will only join the first 2 files.. the rest of the 3 or 4 files are ignored. Any other ideas??
Copy the files to a windows pc and burn with alcohol 120,thats what splits the files that way.
yes, I renamed the files to read:
File.iso.001
File.iso.002
File.iso.003
File.iso.004
etc.. but it only takes the first 2 files and joins those. As I said, it ignores the rest of the files. Has anyone else had luck joining more than 2 files? Is Split & Concat capable of doing so, or maybe I'm just doing something wrong?? -
yes, but mostly with pieces properly downloaded and have passed a hash check.
Were these files part of an .rar archive originally?
if not, are you sure they were downloaded correctly?
if 3 and 4 are bieng ignored, chances are they are
incomplete and not passing a hash check...."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
The files need to be burned by alcohol 120!!!Simple as that.
does Alcohol 120 simply merge the files into one .ISO, so that I may drop it into a program like Toast? or does it actually burn all the files itself (TITLE.mds, TITLE.mdf, TITLE.md0, TITLE.md1), directly to DVD?
Thanks! -
All the files will be burned to one dvd by alcohol as long as the file names are what alcohol named them,dont think it will merge them to a single iso.
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 09:27 -
burning .mdf to disc for chipped PS2
By kanedakaori in forum MacReplies: 1Last Post: 13th May 2009, 11:00 -
burning multiple mp4 files to DVD format
By dvdnewbie64 in forum Newbie / General discussionsReplies: 2Last Post: 20th Mar 2009, 14:59 -
Burning 1000's of files to multiple dvd's
By lordhutt in forum ComputerReplies: 12Last Post: 14th Dec 2008, 16:45 -
extracting vobs from mdf files
By uglijimus in forum Newbie / General discussionsReplies: 7Last Post: 15th Jun 2007, 14:15
