Happy New Year everyone!
I am trying to make my Sony AVD-K800P a region free player. From what what I have learned up to now, Sony is the hardest brand to unlock, there is very little information available.
Does anyone know the equivalent DVD Player Only model number for the AVD-K800P Home Theater?
Thanks,
Ted
Ted
All DVD players can't be unlocked. There may not be an unlock code for your player. Also, firmware changes by manufacturers during the production run sometimes break known hacks that used to work but no longer do because of the firmware change.
Sony players typcially support it out of the box or they don't. Very few can be hacked and the hack typically requires special hardware, it isn't a simple remote code.
Google is your Friend -
That's what I was afraid of. DVD players are cheap enough these days. Does any "name brand" make a region-free player?
Thanks a bunch.Ted -
Philips makes a variety of players that can usually be unlocked. Oppo
http://www.oppodigital.com
makes some highly regarded players that come region free out of the box. They aren't cheap, but you get a higher quality machine for the money with better components than the cheap players use.
Sony BDP-S500 DVD Region Q's
By DJAGE in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th May 2016, 14:20 -
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 17:12 -
Sony BDPS360 Multi-Region DVD help
By efiste2 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 4th Mar 2010, 12:57 -
Change Sony BDP- S350 From Region (1) to Region (4) can it be done?
By MOTHGIRL in forum DVD & Blu-ray RecordersReplies: 1Last Post: 30th Sep 2008, 22:58 -
Sony DVP-FX720 region restriction - using DivX waiting for region free code
By wig in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Aug 2008, 05:34
