  1. Member SE14man's Avatar
    Jul 2005
    Queensland
    I am trying to send someone a series of funny jokes off msn messenger.
    For them it keeps saying the file is potentially harmful.
    I was wondering if there was a bit of software or something i could use to stop their software saying that the joke's im sending them is harmful and let them open them?
    Many thanks!
  2. Member daamon's Avatar
    Melbourne, Oz
    Try changing the file extension to something innocent, like ".doc" and then tell them to change it back to what it was originally.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  3. Member SE14man's Avatar
    Jul 2005
    Queensland
    I'm a cockney pommy too.
    Born n bred in Woolwich.
    Im an SE London geeza.
    Dec 2006
    Why would you want to disable someone else's security-measures? Can't you just type the jokes into MSN? If you are sending txt or doc files then they can still access them - or are you trying to send an exe file?
  5. Banned
    Freedonia
    We don't know enough about what you are doing to help much. Are you sending them as an attachment? Some sites block certain types of attachments in email. Are you just cutting and pasting them into email? That could also cause your email to be blocked, depending on the format of the text you copy. It could also be that your email address is a problem - maybe a lot of spam gets sent from people on your domain, maybe your domain is blocked by an anti-spam filter, etc.
