Hey,
The main reason why I didn't post these questions in my other thread is that thread was direct to encoding conversions of video.
Audio: What type is most likely will be in an HDTV movie? If by any chance it's in high quality DTS or bigger audio, how on earth do I convert it to 5.1 AC3? I prefer using 5.1 AC3 for movies. What freeware tools can be use to convert or encode from high quality audio down to standard audio?
	If by "HDTV movie" you are referring to something broadcast on TV but in high definition (ie. like on HBO HD or something similar), ONLY AC3 audio is used. If you are referring to either BluRay or HD-DVD, the 2 high definition DVD standards, then the answer is quite complicated as both support a variety of audio formats. There is no need to convert audio from high definition broadcast TV as it's already in AC3 format. DTS is not allowed to be used in broadcasts, probably because of its high bit rate.
  HDTV makes DVD movie look "less" like a movie?By breakchange in forum DVB / IPTVReplies: 73Last Post: 6th Oct 2011, 10:28
  Could the in-movie icon lead to burn issues on 60hz lcd hdtv? bluray+hddvdBy yoda313 in forum DVB / IPTVReplies: 5Last Post: 26th Feb 2011, 11:15
  Movie studios again demand HDTV disabling powers from FCCBy drjtech in forum Latest Video NewsReplies: 2Last Post: 11th Sep 2009, 01:30
  Can't play HDTV wmv movie on my PCBy mikee55 in forum Video ConversionReplies: 1Last Post: 10th May 2007, 11:44
  Can't play HDTV wmv movie on my PCBy mikee55 in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2007, 10:07
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
