Just got the 5982, put in my usb flsh and it sees it fine, go to a .jpg I put on it and the preview works fine, select the pic the screen goes blank, the display says "JPG" Something and stays black, after about 10 seconds comes back to the file/directory listing.
Using HDMI cable for video, coax for audio
Any ideas?
Tack (Swedish for Thanks),
Kevin
Just some wild guesses, which may or may not help.
1) The resolution of your JPG may be too large for the player to display it. I don't have any ideas what resolutions this player supports. (This is my best guess as to what is happening.)
2) There might be issues with your USB drive. Don't use NTFS formatted USB drives. FAT32 or FAT should work OK with your USB drive.
Phillips 5982 no 5.1 over HDMI :(
By Fearnot in forum DVD & Blu-ray PlayersReplies: 4Last Post: 24th Mar 2008, 23:49 -
Weird Problems with Phillips 5982 (Jerking, desynch) with DVD's
By Fearnot in forum DVD & Blu-ray PlayersReplies: 5Last Post: 16th Dec 2007, 00:46 -
Phillips 5982 - Which receiver inputs for sound when using HDMI ?
By Fearnot in forum DVD & Blu-ray PlayersReplies: 19Last Post: 13th Dec 2007, 17:45 -
Phillips 5982 Error - Weird Characters on LCD
By kokaine in forum DVD & Blu-ray PlayersReplies: 2Last Post: 12th Nov 2007, 14:58 -
Phillips DVP 5982 Subtitles do not work
By shawnh in forum DVD & Blu-ray PlayersReplies: 3Last Post: 14th Jul 2007, 09:37
