I'm using my Lenovo computer, which runs on Windows Vista, and when I minimize a window, it won;t let me bring it back up, allit does is make that annoying ding noise. I'm asking because this could lead to a problem later.
What do you think could be the problem?
dunno...but if you don't get an answer, try here
http://www.pcadvisor.co.uk/forums/index.cfm?action=showforum&forumid=1 -
If you can't get the window back by clicking on it in the Taskbar, use Vista's function where it displays all the windows and allows you to cycle through to the one you want - it's one of the default buttons in the bottom left Quicklaunch Toolbar.
I believe Alt+Tab does the same thing. It does in XP.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Computer Won't Shut Down
By DarrellS in forum ComputerReplies: 5Last Post: 23rd Jun 2010, 00:51 -
HELP with some computer problem,won't turn on??
By demolitionman1985 in forum ComputerReplies: 6Last Post: 8th Sep 2008, 12:35 -
Computer Won't Power On
By Sakuya in forum ComputerReplies: 8Last Post: 2nd Dec 2007, 01:24 -
Computer keeps shutting down, won't stay on.
By Super Warrior in forum ComputerReplies: 6Last Post: 9th Aug 2007, 15:34
