Most major network stations are currently broadcasting HD or upscaled SD 24x7 on the main digital channel. ATSC allows realtime switching from 1080i or 720p to 480i but most legacy HDTV set tuners glitch badly when this is done. Around here PBS is the only one doing format switching and then only twice a day.Originally Posted by vhelp
By keeping the broadcast signal 1080i or 720p, local stations are free to switch between 480i 4:3, 480i 16x9 and HD 16:9 sources on the fly at their end without glitching the home TV sets. Commercial breaks sometimes switch from HD to upscaled SD several times.
Current HDTV sets are good but not great at handling the aspect ratio shifts. Some maintain vertical height for SD 16:9, some have the four side black unless changed manually.
It will be interesting to see how the ATSC tuners intended for analog sets handle aspect ratio. The LG-Zenith box indicates 4 aspect ratio presets. One would be letterbox, another would be side crop.
Results 31 to 42 of 42
http://www.kiva.org/about -
Analog and digital come through the same coax cable but on different 6MHz channels.Originally Posted by vhelp
US cable companies send analog on the lower channels and digital on the upper channels. Analog channels use NTSC. Digital channels use QAM modulation. Each 6MHz QAM channel can carry up to 36Mb/s of data.
02-06 Low Band VHF
95-99 Mid Band VHF (sometimes used for digital QAM)
14-22 Mid Band VHF
07-13 High Band VHF
23-36 Super Band
37-64 Hyber Band (sometimes used for digital QAM)
65-158 Ultra Band
(mostly used for digital QAM with 6-12 subchannels per 6MHz channel)
Digital HD like SD is just data over cable. Quality depends on bitrate assigned per channel. Digital channels are tuned by a cable box or clearQAM tuner (unencrypted channels only). The cable company determines channel assignments and bitrate per channel.
1920x1080i/29.97 and 1280x720p/59.94 use about the same bitrate. ATSC stations are broadcasting at 12-19Mb/s. Most cable systems seem to be passing the bitrates given to them over the data line from the TV station which can be higher than broadcast bitrates. So in summary, quality is determined by the cable company. The tradeoff is quality vs. more channels.
Lost is broadcast by ABC as 720p/59.94 with frames repeated in a 3 then 2 sequence (e.g. AAABBCCCDDEEEFF). Normal IVTC will not be successful. The idea is to remove replicated frames to get back to ABCDEF 24p. 1080i uses similar telecine patterns to classic 480i. Normal IVTC can be used for 1080i.Recommends: Kiva.org - Loans that change lives.
Morning all..
edDV, thank you for your constructive criticism, much appreciated
Oh, I am just reminded of that time when I used to get all those other HDTV channels
back in the month of February. I should test my tuner card out and maybe report back
the results (in that other -old- thread) .. maybe.., cause I'm dying to see how 1080i
plays (handles on my computer) and looks on my screen.
Have a good day, everyone.
-vhelp 4499 -
While true in most cases about Cable and Satellite TV not needing a converter box once the switch occurs, you have failed to point out that if you have the Coax connected directly to your analog TV, you will in fact need a converter box as of 2/19/2009. You may either opt to use the boxes provided by your cable company (upgrading your service), or purchasing a digital to analog converter box. Since both major satellite providers in the US (DirecTV and Dish Network) require each set have a set-top box, you will not need to purchase a converter box.
As pointed out by another user, the model of SDTV that you have is perfectly fine for over the air, as well as satellite and cable broadcasts as well.
Bottom line for all users in the US: on 2/19/2009, if you have an older tv you will need a converter box of some sort. If you have an SDTV or HDTV, you are fine, they have ATSC tuners already. Best Buy was one of the first dealers to make the full switch. They are no longer selling any TVs without ATSC tuners. Circuit City is in the process of making that happen now as well. Just make sure, if you are shopping for any new TV, that it does in fact have an ATSC tuner. The Law (FCC) now requires sets that do not include one to have a disclaimer statement in full view of the consumer, so it should in fact be on all labeling.
Now, if they would just follow through on the DVD recorders, we would be fine. -
Yeah, I'm wondering if and when the dvd recorders do begin their new ERA in this market,Now, if they would just follow through on the DVD recorders, we would be fine.
will they downsample to 720x480 DVD specs or keep the HD 'type' spec.. ie, 1080i and 720p
resolutions. I inquire because so far there is no dvd (or should I say, HD-recorder) that records
these type of video content. Maybe the consortium hasn't ruled on what the final destinate
will be. I don't know.
-vhelp 4501 -
This isn't exactly true. Until 2012, cable carriers will be required to either continue carrying local broadcast stations in analog format, or provide (at no extra charge?) a set top box capable of performing the D/A conversion.Originally Posted by spikeylikesit
http://www.abqtrib.com/news/2007/sep/15/fcc-extends-deadline-analog-subscribers/
My guess is that they'll start phasing out analog channels in 2009. They may reduce the analog tier to channels 2-13, enough to carry the local broadcasts, and use the rest of their current analog spectrum for digital.As for the nation's analog cable subscribers, cable operators must either convert the digital signal to analog at the point where the cable signal originates or supply customers with a "down converter" device that will change digital signals to analog at the TV set. -
Comcast has already started phasing out analog channels in our area. They moved "Oxygen" to the digital realm without warning or announcement. Just one day, if you tuned to that channel you got static. Of course it was just Oxygen so no-one cared, but now they are planning to move the local access channels out of the analog range and the local government is up in arms about it, writing letters of "disappointment" to Comcast and crying in the local paper.
Buy My Books -
Further to what jagabo said, what you say here applies only to those receiving analog TV from an antenna. Cable will be no different in Feb, 2009 than it is today. The analog channels will still be tunable by analog sets. For most cable systems these channels are already using the digital feed from the TV station. The conversion to analog is done either at the cable company head end, or in the set top box.Originally Posted by spikeylikesit
There are two changes that the FCC is demanding of cable companies as part of the digital changeover.
1. That analog versions of over the air broadcast stations continue to be available to basic cable subscribers until 2012. If the cable company decides to go all digital, they are required to provide a cable box to basic service subscribers at no additional cost. The idea here is that a basic analog cable subscriber should see no additional cost to continue to receive local TV stations over cable after the changeover.
2. The cable companies are also required to provide unencrypted "clearQAM" digital versions of the local "must carry" primary digital channels to basic service subscribers. That means digital sets with QAM tuners will be able to tune the digital version of the local channels (SD or HD) without the need for a cable box or a high definition service subscription.
Note that this only applies to "must carry" class stations. "Retransmission Consent" stations (major network affiliates) negotiate their own terms with the cable system but most will be available unencrypted as clearQAM digital as well even to basic service subscribers. PBS has negotiated a separate agreement with the cable industry that their primary channel and all subchannels will be made available as clearQAM digital to all subscribers without need for a cable box. Note also that an ATSC tuner will not tune cable QAM. You need a tuner which can also tune clearQAM.
The net result is an SD or HD TV set with QAM capable tuner will be able to directly tune the local digital channels as clearQAM without a cable box with a basic service subscription. This is great news for satellite subscribers who can now get the locals in digital with just a basic cable subscription.
The FCC digital requirement and the user demand for more HD cable channels will gradually force a reduction of analog cable channels in favor of encrypted QAM. Each analog channel can be replaced with up to 12 SD or 2 HD digital channels. Analog cable customers will see a steady reduction in analog cable channels in coming years. Smaller systems will be forced to eliminate analog channels completely and require use of a cable box.Recommends: Kiva.org - Loans that change lives.
This going to vary locally. Some cable infrastructure has only 1970's 550MHz capacity (no ultraband). These systems must either upgrade the infrastructure or convert to all digital. Systems installed later will have 750MHz to 1GHz capacity. These systems can continue with analog while adding more digital services in the ultraband. In time these systems will also need to reduce analog channels to allow for more digital HD channels.Originally Posted by gadgetguyRecommends: Kiva.org - Loans that change lives.
I was one of the people demonstrating components for the 80's HiVision system at NAB (not for Sony). The early studio infrastructure was wideband analog component (up to 30MHz per component) and the studio pictures were stunning limited only by camera and monitor technology. But when it came to recording, the early MUSE digital encoding left much to be desired. In the 90's digital encoding and compression issues were solved to the point where an all digital infrastructure could be used from the studio camera to the home screen. The 2000's are seeing this technology implemented with dramatic cost reduction to the point where digital high definition acquisition and editing is becoming possible in the home.Originally Posted by davideck
As you can see in the following article, 1991 futurists were projecting 2010 for the feasibility of digital broadcasting let alone home HDTV production. The digital broadcasting issues were solved by 2000 a full decade before projected.
Refs
NYT 1991 article on HiVision
http://query.nytimes.com/gst/fullpage.html?res=9D0CE2DE1039F935A15752C1A967958260&sec=...pagewanted=all
MUSE
http://en.wikipedia.org/wiki/Multiple_sub-nyquist_sampling_Encoding_systemRecommends: Kiva.org - Loans that change lives.
'Comcast has already started phasing out analog channels in our area.'
Same in my area but they choose ones no one watches much. -
Without adding anything to the debate..
This is what you said
But that might muddy the issue for an already confused reader..I'm so far away from a transmitter, that I could use an antenna (analog or digital) if I wanted to. I either watch cable or DVDs.
What you meant to say
I'm so far away from a transmitter, that I could not use an antennae (analogue or digital) if I wanted to..
People in the uk are already making this mistake dvb-t=hdtv (Freeview is not Hidef and wont be till 2012 (or later) write to your MP if you want it changed.
Incidentally the spare spectrum is being auctioned off at this minute, long before its available.. what GOv wouldnt want the Cash now...especially when you've got an Olympics to fund.Corned beef is now made to a higher standard than at any time in history.
The electronic components of the power part adopted a lot of Rubycons.
Surge Protector and Analog Antenna
By prayami in forum DVB / IPTVReplies: 4Last Post: 18th Dec 2013, 01:28 -
What happens to Cable Analog in 2009?
By Mormegil in forum DVB / IPTVReplies: 9Last Post: 22nd Sep 2007, 11:04 -
Digital antenna v analogue antenna - does it affect quality?
By Rudyard in forum DVB / IPTVReplies: 14Last Post: 13th Sep 2007, 05:51 -
February 17, 2009 - the analog deadline.
By AlecWest in forum Latest Video NewsReplies: 54Last Post: 8th Jun 2007, 08:02 -
Converting PAL RF tv antenna to NTSC RF antenna signal?
By SamGR in forum Newbie / General discussionsReplies: 17Last Post: 23rd May 2007, 15:05
