Hi,
I copied a DVD to a directory, and I would like to play it using 'vlc'.
Does anyone know how can I do that?
Thanks a lot!
That worked for 2 copied DVDs, but for other 2, nothing is displayed, and the horizontal browser goes fast from the beginning to the end.
I ripped one of them using 'acidrip' to a mpeg file, but this way no menus are displayed.
Any ideas?
Thanks! -
Acid rip would have just copied the mpg files without any nav packs. Just right click on the file(s) copied and choose open with VLC. Or right click on the folder and open with VLC.
VLC needs a VIDEO_TS folder with IFO/VOBs inside it to play as a DVD. If those files aren't there it won't act as a DVD Player, but rather a normal file player.
To backup a complete DVD use a different program (vobcopy, XDVDShrink). AcidRip is a DVD-Ripper, for converting a DVD to another format (Xvid, DV) -
I used 'vobcopy', and it created 3 .vob files. I copied them to a directory, and opened it with 'vlc', but it starts playing the film, not displaying the main menu (I need to define the language for the subtitles).
I will try to use the '--mirror' option in 'vobcopy'.
Any ideas?
Thanks a lot! -
Using -mirror will copy the entire contents of the VIDEO_TS folder. This will include all menus, and all video files.
What is exactly you're looking to do?
Create a one to one backup of the DVD including all contents of the DVD for playback on the PC? Copy just the main movie for playback later? Compress to a smaller format (xvid) to take up less space? -
The thing is: I rated 4 DVDs to watch, but I did not have time to. As I have to return them today, I wanted t copy to my HD, watch during the week, and delete later.
But I need to access the link to choose the subtitles language.
As I wrote before, I just copied ('cp') the 4, and 2 of them worked fine ("Capote" and "Nacho Libre"), but "Age of Ice 2" and "A Scanner Darkly" did not.
I am playing "A Scanner Darkly", and it started directly in the making-of. I managed to display the subtitles in portuguese, but I can not make the main menu to be displayed.
Any suggestions?
Thanks!
Problem with Blu-ray rip file playing in MPCHC and VLC
By brianp6621 in forum Software PlayingReplies: 1Last Post: 19th Oct 2009, 12:26 -
Problem Playing Copied DVD+R DL DVDs from CSS Protected Original
By bpbenda in forum DVD RippingReplies: 10Last Post: 24th Sep 2009, 10:04 -
Playing an IMG file using VLC (or Nero) -> ONLY half screen displayed. W
By htp367 in forum Software PlayingReplies: 5Last Post: 24th Jul 2009, 15:37 -
VLC player not playing MKV file
By GLE3 in forum Software PlayingReplies: 3Last Post: 15th Feb 2009, 16:39 -
Can Sony PS3 system play copied DVD movie?
By coody in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Jan 2009, 01:33
