Hey,
I recently encountered a problem- Adobe Premiere Elements 3.0 stopped working when it used to work fine for me. Now, when I open it and open a project or chose a new one, the screen comes up and it immediately says there has been a "Serious error" and it needs to close, without further information. Any suggestions/tips/common known solutions for this? Thanks,
I tried that already and I got the exact same results as before, but thanks for the advice.
I assume it is Premiere that is giving you the error? Have you tried the Adobe forums? Any other changes to your system lately?
Google is your Friend -
Yep, it's Adobe, since WMM works fine...well, as fine as could be expected I mean. No big system changes I can think of, though I recently defraged my harddrive and uninstalled the DivX codec. I did reinstall DivX, to see if that was the problem but no change, and I doubt it was the defrag. I didn't know Adobe had forums though, I'll check there now. Thanks!
By willmington in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2011, 04:14 -
Rendering in premiere elements 8!
By cnl1339 in forum EditingReplies: 3Last Post: 27th May 2010, 17:58 -
Adobe Premiere Elements 7 keeps crashing
By NP11073 in forum EditingReplies: 7Last Post: 22nd Oct 2008, 02:23 -
Premiere Elements 4 HELP!
By tczerwinski in forum EditingReplies: 3Last Post: 28th May 2008, 09:55 -
By sm head in forum Capturing and VCRReplies: 2Last Post: 28th Jun 2007, 15:42
