I would like to transfer video files I created from my computer to my Blackberry 8830 microSD card. The videos are in MPEG-2 format and I need to transcode them into MPEG-4 format. The specific format specs that are compatible with my Blackberry are as follows:
MPEG-4 Part 2 (Simple Profile and bvop, including DivX 4)
File formats - .avi, .3gp, .mp4, .mov
Video - Up to 320 x 240, up to 800 kbps, up to 30 frames per second
H.263 (Profile 0 & Profile 3)
Video - up to 320 x 240, up to 800 kbps, up to 30 frames per second
Windows Media® Video (Simple Profile)
File formats - .wmv
Video - Up to 320 x 240, up to 800 kbps, up to 24 frames per second
Note: Windows Media Video is supported in BlackBerry Device Software 4.2.1 and above.
What program can I use to transcode video files into the Blackberry compatible format listed above??
thanks. I used XviD4PSP and chose the Blackberry format for encoding. The video came out nice and played well for several minuts. However, after about 10 minutes or so the video started to stutter, I assume to resync with the audio, and then the fps seemed to drop off considerably, resulting in a choppy picuture that was way behind the audio. Any ideas on a fix for this??
What type of audio and bit rate are you using? Also, if it's MP3 is it VBR or CBR? Sync problems are almost always audio issues, although I suppose if you used too high a video bit rate when encoding that could also be a problem.
MPEG Streamclip to join files but not transcode?
By Corbey in forum Video ConversionReplies: 2Last Post: 12th Apr 2013, 12:18 -
multiAVCHD will not show files in transcode preview that it did previously
By Onceler2 in forum Authoring (Blu-ray)Replies: 9Last Post: 6th Oct 2011, 21:20 -
WTV/DVR-MS files into usable MPEG format?
By CursedLemon in forum Newbie / General discussionsReplies: 6Last Post: 24th Jul 2010, 09:21 -
MPEG II to MPEG (DVD): Transcode or reencode?
By Jeroen1000 in forum Video ConversionReplies: 8Last Post: 12th Feb 2009, 17:44 -
VIDEO-TS.......how do i change format from disc to my video files
By COT51E in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 25th Oct 2008, 11:32
