ok i have burnt a 2 hour analogue video to a dvd-r , success . what i would like to no is how to download the DVD me pc ,all i see is RM/TS FILES .What do i need to do to download to my hd, then i can edit
sorry if i am a bit "basic" i am trying to learn on the run
regards pat
Results 1 to 10 of 10
How? Using what?Originally Posted by nobbydadog
/Mats -
insert dvd into dvd rom/ download onto hard drive to be able to read on pc how? what is rm /ts files i dont know . Maybe i am talking bollocks , .I just thought someone might be able to help constructvely in basics The two hours of rugby DVD footage needs editing to highlights. i have tried to rip it on a dvd to mpeg software but it only converts an hour . what i need to do nowOriginally Posted by mats.hogberg
pat -
If it is a regular Video DVD, rip it to HDD with DVDDecrypter. Then use VOB2MPG to get the mpg file.
But my initial question remains: How, using what, did you create your DVD?
/Mats -
thanks for the reply On the point of your how i did it. Not being facetious. I have a bush combi dvd/vhs recorder that burns on dvd-r i used a VERBATUM DVD-R on short play and finalized it to play on my pc and laptop with success The result was a 2 hour dvd that i didnt know what to do with regards editing hope this helps
pat -
As Mats said, Rip it to HDD with DVDDecrypter. Then use VOB2MPG to get the mpg file.
Have you installed these two programs yet? -
downloaded the first one just downloading files on the VOB2MG but it is taking an age
pat -
sorry about this but when i try to download VOB2MPG it install ok .then i get the message that it has encountered a problem and needs to close. I have uninstalled in add /remove then reinstalled but the same applies could you help , i had the same bother before
once again sorry for the messing about
PAT -
ok we are up and running on vob2mpeg but now we have another hitch . When i convert it appears to do two of the first chapters out of 30 that there is . When i copied each chapter form VHS r paused some clips then carried on and i also stopped recording for another day so wether that is the problem i dont know .Do i copy another DVD-R from the original and so have one complete recording , or do i transfer back to vhs and then copy again ,with i reckon a loss in qualty. if i do copy a duplicate disc do i use shrink or imgburn as you suggested
or is there a better way that you can advise
thanks for your patience
pat
Copying Segments From DVD`s Advise.
By opopopo in forum EditingReplies: 9Last Post: 9th Jan 2010, 05:41 -
Looking to buy a new DVD Burner...Need advise
By BrokenOne in forum DVD & Blu-ray WritersReplies: 3Last Post: 27th Mar 2008, 09:43 -
Looking for advise about of a new dvd burner
By stoico1 in forum DVD & Blu-ray WritersReplies: 3Last Post: 26th Mar 2008, 17:35 -
What would you advise for a good cd/dvd Duplicator
By scustalow in forum ComputerReplies: 1Last Post: 9th May 2007, 12:52 -
some advise for a beginner (VIDEO /DVD)
By nobbydadog in forum Authoring (DVD)Replies: 3Last Post: 8th May 2007, 18:32
