  1. I had did 4 vts titles but I had forgotten to go to the menu file to arrange them. So now they are one on top of the other. My question is how can I fix this without having to redo the project?
    Happy New Year
  2. What step are you on in the project?
    Have you closed S2D?
    Did you save a project file?
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
  3. Unfortunately once the DVD is completed I close and delete all of the files. So all I have now is my DVD.
    I had done many projects and rarely forget to do my menu. I must have been distracted that day.
    Thanks in advance for any suggestions.
    Randall
  4. Well, it shouldn't be too hard, here's what I would do:
    1. Rip the DVD to your Hard Drive.
    2. Use VOB2MPG to convert the files to MPG (just makes it easier if they are over 1GB)
    3. Import the resulting MPG files as assets to S2D.
    4. Reauthor your Menu/DVD the way you wanted it.
    This way there is no conversion neccessary, just a recreation of the DVD structure.
    Dwight
    - Herm Albright
  5. Thank you very much. Worked like a charm. I had searched for several hours and could not find anything to help. I should have checked under Chrissy's site first.
    Happy New Year
    Randall
