Please help me figure this out!! After I capture videos from my sony DVD handycam and create mpegs saved to MY VIDEOS, I then go to play the movies in ANY of the DVD players in my programs, and the audio disappears! BUT, when I use Sonic and burn the mpegs to a DVD disc, the audio is there. My daughter got a zune for Christmas and I have been trying to convert the mpegs in MY VIDEOS to WMV files for her, but, again the audio is missing. WHAT ON EARTH IS GOING ON?!?!![]()
Thanks, SmokieStover..... but now how do I seperate the AC3 file from the Mpeg movie?
I don't have a DVD HandiCam, but have been stuck with the job of working with a half dozen or so disk from a friends camera......fortunately for me the Sony Cam gave up the ghost before its first birthday. Just one more reason why I now buy no Sony hardware.
I have watched on the PC video he did with image mixer, and it looked fine. Not sure if it was WMV.
Do you have mpeg or VOB sets?
If you have VOB, do as already suggested and extract to one mpg2 using VOB2MPG. I can't find any options in my version for demuxing or converting the audio to LCPM/Wave.
Then open the mpg2 with VideoReDO>stop the playback>click on "Save As" (answer yes to the question)> click on "Options" in lower right hand corner>check "re-encode" audio and then select "LCPM/wave". I leave the output on Program Stream (works for me when encoding later to WMV). If that doesn't work, repeat all the above outputting to elementary streams.
VideoReDo is a fine, frame accurate editor. I suspect you have footage that you want to leave behind. If this tool does the job you asked about, give it a try at editing. For cut-editing and joining, I prefer working in scene mode. -
I have mpeg... Can you help me with that? I appreciate your time with this!
Audio Disappears during Video Capture
By sdculp in forum Capturing and VCRReplies: 23Last Post: 28th Jun 2010, 14:45 -
Audio Disappears..
By Hairykiore in forum Video ConversionReplies: 1Last Post: 25th Feb 2010, 19:28 -
ADS DVDxpressDX2 Audio Disappears during Video Capture
By fjrnut in forum Newbie / General discussionsReplies: 2Last Post: 2nd Oct 2009, 12:53 -
Video playback disappears, audio ok
By photoman99 in forum Software PlayingReplies: 7Last Post: 15th Aug 2009, 00:38 -
Audio Disappears After VHS Capture
By drjax in forum Capturing and VCRReplies: 0Last Post: 11th May 2007, 03:48
