What is wrong with it exactly?Originally Posted by guns1inger
and how does it 'crap out' my DVD Player? (Is there any evidence?)
I find this interesting , I do agree that its unstable, I have had problems just getting it to work in past but version 8.0 has been OK , quicker and uses less disk usage (still 100% CPU with no option to lower) Ive only ever used WinAVI and Convert X to DVD and find that WinAVI finish is better while Convert X takes twice as long for lesser finish (but is good to use if you want to do other stuff whilst converting - low CPU usage) thats why I have BOTH, I use WinAVI if i can otherwise its VSO... also WinAVI allows to add multiple files to merge into one file, when i try with VSO it just outputs several files
Results 31 to 33 of 33
while using an old version of WinAVI:
--- apply filters;
--- choose GOP length;
--- define GOP structure;
--- choose different quantize matrices;
On my 7-yo Pentium IV, TMPGEnc Plus needs 90 minutes to produce a 90-minute long
VCD-compliant video, whereas WinAVI did the same job within 50 minutes or less.
Both CCE and MainConcept were faster than TMPGEnc, but still slower than WinAVI.
However CCE and MainConcept have always had a good reputation because
they have always deserved it. -
I dunno what any of that is? lol
i would like to try some other software, what do you recommend?
I have K-Lite Mega Codec Pack and DivX 6
Im busy looking at FFdshow config, where can i learn what all these options are like Quantization etc?
the only problems i have with Vdeo Converting (and want to fix) is what i call 'Frame-Dropping' (dunno if thats the right term or not) but where the camera pans fast or fast images appear to stutter... How can i stop that?
thanks
Is DivX avi is better than flv, wmv, and mov?
By dread in forum Newbie / General discussionsReplies: 12Last Post: 20th Apr 2011, 11:38 -
Converting AVI (DivX/XviD) to MP4/MOV/3GP...
By JaleAlbatros in forum Video ConversionReplies: 5Last Post: 23rd Jul 2009, 17:51 -
Converting WMV to burn on DVD to play on DivX
By ez2cy in forum Video ConversionReplies: 30Last Post: 20th Dec 2008, 03:54 -
Banding when converting MOV to WMV
By whoisquilty in forum MacReplies: 2Last Post: 22nd Jul 2008, 10:35 -
Converting WMV to divx/xvid
By mattr in forum MacReplies: 1Last Post: 3rd Jan 2008, 09:23
